What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
battery not charging
I saw a posting here within the last few days that said that if the battery charging light on the dash board was out that the battery would not charge up.. Clarification please???
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-09-2004, 07:45 PM
Burn the fire.
Brando's Avatar
Not true.
Mine goes out after revving up, but battery doesn't like to stay charged. Voltage regulator and output of alternator are nominal... What gives? Bad battery?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-09-2004, 07:53 PM
Send a message via AIM to TheCooler
Re: battery not charging
The light bulb in the dash is actually part of the circuit ...so if it doesnt come on when you turn the key to on then your battery wont charge. Weird problem.
The most likely cause of charging problems is the voltage regulator (happened to me) or bad battery (happened to me).
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 06-09-2004, 08:41 PM
Originally posted by Brando
Not true.
sounds like the voltage regulator actually.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-09-2004, 08:43 PM
bearone2's Avatar
it's like xmas tree lites in series.
if the alt lite doesn't come on with the key in the ignition, car not running, the system won't charge.
if the light doesn't come on when the key is turned on, how will you know if the alternator fails.
i posted this a while back and it happened years ago in a volvo with a bosch ignition system, same thing.
no alt lite with key on, both systems showed a little over 12v when running, replaced the lite bulb in both cases and showed 13.7/8 after being started.
the volvo info came from a volvo service writer and he claimed it was one of the poorest designs he'd ever seen and golly gee, it's a bosch system in the p-car.
i'm used to checking lites when the system is powered up, silly lites like for oil pressure, generator + a few more and then making sure all of the lites are out as oil pressure/voltage come up before i go to work and before driving to work.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-09-2004, 08:55 PM
3-924's (Sold)
1967-912 (Traded)
Old 06-09-2004, 09:06 PM
bearone2's Avatar
you're welcome
Old 06-09-2004, 09:28 PM
