-   -   Brake Job / AC Estimate (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/167063-brake-job-ac-estimate.html)
drewcare 06-09-2004 08:34 PM
Hello all. First time poster here...
I just got a pretty steep estimate on a brake job: $800
I have an '84 944
I need all 4 rotors replaced, as they are warped, and all new pads (of course).
The estimate I got was for Zimmerman Rotors, Jurid Front Pads and Textar Rear Pads. He also mentioned something about sensors on the pads and seals. He said he would repack the bearings and everything. My question to you guys... is it worth it to go through him or should I just get the parts off here. They just say OEM, so they dont really give me too much info, and should I do it myself? I've done brake jobs on other cars (just never on a Porsche) I'm not sure if its any different.
He also gave me an estimate on the AC -- the condensor needs replaced, and he quoted me about $650 for replacing that and converting it over to the newer style instead of sticking with the old freon. From what I gather, this is a pretty good price, and I don't want to do this one myself... just seeing if this is a good price too ;)
TheCooler 06-09-2004 08:38 PM
Do the brakes yourself and let him do the ac since thats a decent price.
Wolf1 06-09-2004 08:54 PM
LIST COST
A/C Condenser
R1030-23547
In Stock United States $550.73 217.46
Brake Disc
N1000-20721
In Stock Zimmermann $118.20 58.63
Brake Disc
N1000-23523
In Stock Zimmermann $130.95 86.47
Brake Pad Set
N1010-23068
In Stock Jurid $94.66 75.83
Brake Pad Set
N1010-23522
In Stock Jurid $141.00 67.43
Wheel Seal
K8010-20723
In Stock $11.92 7.06
drewcare 06-10-2004 04:58 AM
what are those part numbers from? or are they just general part numbers. Also, where did you get the prices? I'm specifically interested in the lower of the prices :D
Any suggestion on where to get these parts?
I think i'm going to take your adive and do the brake job myself and save a little bit
Thanks for your responces.
Eli K 06-10-2004 09:16 AM
Brakes are just as easy to do as any other car out there. I was motivated to do mine after getting a similar quote. While you're in there might as well repack your bearings.
Wolf1 06-10-2004 05:38 PM
They are actual part numbers and prices from here.
http://www.thepartsbin.com/
You may be able to find them cheaper if you look around, I was just looking at this site when I read your post..:p
GHEN 06-10-2004 06:19 PM
As I've said before, the brakes are easy, good starting project.
GHEN
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
