scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Angry about to throw in the towel
well my car is being stupid... ill be driving along when all of a sudden the rpms slowly drop to 0. no matter how much gas i give it the rpms just fall. if i try to pop the clutch the rpms go up then fall. when the rpms reach the bottom the battery and oil light come on. once i stop and i try to start it it starts right up. this happens at completely random times. its happened on the highway at 80mph, on the street at 20 and everywhere inbetween. what would cause this?
im really just wondering what would cause this. lately i have been adding up the prices on things to fix... its just too high. ive pretty much made up my mind that im ganna sell this car. only thing i dont know yet is whether im going to part it out or sell it as a whole...
but what cause the problem i described?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 06-09-2004, 09:44 PM
Deplorable Member
Porsche-O-Phile's Avatar
The ENGINE rpms go to zero or the speed goes to zero?
If the engine rpm goes to zero I'd suspect a loss of fuel pressure for starters. Have you verified proper flow at the injectors?
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 06-09-2004, 10:39 PM
yes rpms drop to 0... well i would think the injector would be fine, i have reciepts for when they were replaced about 2 years ago. plus the car runs great normally, i have no problems at about 140mph. the car never hesitates or anything like that. i was thinking that the problem would be due to something electrical, like some cold soldering joints going bad or something like that or a relay. now that i think about it it only happens when the car has been for about 10-15 min. fuel pressure regulator has also been replaced about a year ago.
hehe... throbbing member... i love this place, if i got rid of this car i would still read and post on this forum!
Old 06-09-2004, 10:48 PM
Custom User Title
Dave L's Avatar
I had a similar problem, only sometimes it wouldnt start. Driving along it would just die. turned out to be the DME relay
Old 06-10-2004, 04:19 AM
AFJuvat's Avatar
Check your electricals - double check the speed and reference sensors - if they have intermittant contact, the car will die.
CHeck the DME for water intrusion
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-10-2004, 04:52 AM
Feelin' Solexy
Tishabet's Avatar
Check out this thread...I had a problem where mine did the same thing, except instead of happening randomly it happened ONLY when I made right turns.
Engine cutting out when I turn right....
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 06-10-2004, 05:03 AM
TCMdocs944's Avatar
Yes Sheis....
Your car is totalled.
Let me know when I can come and pick it up.
(Remember, if you really like it, it takes a year or so to sort an older car. Lay off the upgrades and spend time getting the little things right. All in all I bet it is still less than a car payment.)
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-10-2004, 05:50 AM
Eli K's Avatar
Long shot but worth looking into.....
Had a similar problem with my audi, hard to diagnose, after extensive testing by the dealer (glad it was still under warranty), appears someone poured sugar into the gas tank!!! Try to remember if you ticked anyone off recently.
Old 06-10-2004, 09:25 AM
Deplorable Member
The good news is it sounds like nothing mechanical - so a lot of really tedious & expensive repairs are out as a cause.
This leaves the basics - air, fuel, and spark.
Is it possible that you have an intermittant air supply blockage? Unlikely.
Fuel - it sounds like possibly an intermittant fuel starvation problem could cause this - check for pinched lines, clogged lines, bad filter, bad fuel pump, etc.
Spark - could be loose coil wire, or possibly the computer control (DME) or its relay, like AFJ said. Start with those things and take it from there.
Black Cars Matter
Old 06-10-2004, 11:41 AM
