Steps on taking Radiator out?
Hey guys..one of my fans on the radiator lost 2 blades :| i have absolutely NO idea how it happened..but the radiator now shudders..because the fan's mass throws off the balance.
How do i take the radiator out? does it come out through the top..or the bottom?
Also..while i was at it, i wanted to remove the A/C system, my friend gave me a BRAND new one so i wanted to replace it..
Any help would be appreciated guys
EDIT: While i was down there..i noticed my front bumper has been deteriourating gradualy since i got my car
What's the best looking lip for the front end for an N/A?
Old 06-10-2004, 12:43 AM
Send a message via Yahoo to bigyagi
comes out from the bottom. you have a couple nuts to release up top, this takes the upper rubber stays , and then the same at the bottom. be careful with the hoses/plastic neck on rad !!
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 06-10-2004, 01:00 AM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Zlatko..you dont need to remove the rad to remove the fans. There are 6 10mm headed bolts that hold the fans in, 3 on top and 3 on the bottom..the fans can be easily removed after taking out the bolts, from below..
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-10-2004, 01:21 PM
Another question..when you turn off the car and it's still hot...one of the fans will run..
However..when you put your key in and turn it so that the electronics come on..the fans are a LOT louder...are both of the fans turned on..or is it just the one that's turning really fast?
One of the supports for the fan broke off..and since the fan is off center by the lack of blades..it shakes and shudders like crazy. If only one of the fans is on when the car is stopped..i wanted to just switch the connectors till i find a fan and support.
Old 06-10-2004, 01:56 PM
SoCal Driver's Avatar
Guess you could pull the ground on the bad fan. The brown wire. Keep an eye on your temps as one fan may not be enough to cool off the engine.
You really want to find a set of the later 6 bladed fans. Much better than the older three bladed fans.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-10-2004, 02:35 PM
I called a mechanic in my area that knows what the hell he's talking about..
This is what concernms me..one of the supports for the fan is broken..probably can be superglued back together..but the concern is a temporary fix that i want right now, till i find some fans.
I kept asking Henry to answer my question, but his english isnt good..he's from Germany.
Alright..
WHEN I TURN OFF THE CAR AND THE ENGINE IS HOT, ONE FAN REMAINS ON. THE RIGHT ONE.
WHEN I PUT THE KEY BACK IN AND TURN IT SO THE ELECTRONICS COME ON, DOES THE RIGHT FAN JUST INCREASE IN SPEED, OR DO BOTH CLICK ON?
I kept asking him that..but he couldnt asnswer He just told me that there were 2 speeds for the fan.
Old 06-10-2004, 02:53 PM
Used & Abused
" knows what the hell he's talking about" Guess he doesn't know what you're talking about then.
Both fans should run.
You only need to remove the 6, 10mm bolts to pull the fan assy out the bottom.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 06-10-2004, 03:15 PM
Where are these bolts?
Old 06-10-2004, 03:27 PM
Used & Abused
Feel around the edges of the housing, they bolt onto the outside edge (sort of) of the radiator
Old 06-10-2004, 04:10 PM
Later model fan circut runs the fans at two speeds using a two ceramic wire wound resistors besides the very slow speed for cooling off.
The later fans work great in the older cars. You don't get the two speeds but you do get six more blades.
Buy a complete set (both fans in their housing with the wire harness) off of eBay or at a junk yard. About $50. You can use the existing wiring if you can't get the harness.
Old 06-10-2004, 05:19 PM
Yep..but hard to find..
Check these out...
Notice something? there's no blade
And this one...it's clipped in HALF!
Then i found this in the fan housing!
Old 06-10-2004, 07:22 PM
Used & Abused
That's what you get for sticking your finger in the fan trying to see if it was spinning!
Old 06-10-2004, 08:00 PM
What? Then my finger would have come off..and not the fan blade.
Old 06-10-2004, 08:03 PM
Used & Abused
Oops, I meant to say, trying to stop it. No your finger wouldn't come off. Hurt, bruised, and swollen yes but still attached! Stupid me thought one of my fans wasn't running after replacing the thermoswitch, the fan blade corrected my thinking fast. Of course it was dark out so i couldn't see.
I also forgot to end it with joke!
Old 06-10-2004, 08:59 PM
bearone2's Avatar
if these were original, 21 years isn't bad.
i relaced with 6 bladers and they're more efficient but not all that much louder.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-11-2004, 06:10 PM
What is the parts code for these 6 blade fans? Is this from a newer 944 ...or a turbo..or an S2? What's the story? :P
Old 06-11-2004, 09:12 PM
85.5 or newer. Think if you go down and buy a new fan you get the six blade units.
Old 06-11-2004, 09:18 PM
Alrght makes sense..but why does Pelican only sell "3 blade" and "4 blade" fans?!? :|
Old 06-11-2004, 09:35 PM
bearone2's Avatar
i got mine right here at pp.bbs
Old 06-11-2004, 10:16 PM
Used & Abused
The 4 blade fan is a typo. It really is a six blade fan IIRC. Call/Email them to confirm this if you want.
Old 06-12-2004, 05:13 AM
