Anyone who has done a clutch job
I just put my new (sachs) release bearing and pressure plate together and (as usuall) I have a question.
My bearing came with 3 thin washers like the two in the photo.
I took apart my old setup and it only had one (see other photo)
I put the new one together with only one of them. Now I am worring that I should use them. Why else were they there?
When I push down on the pressure plate while looking at the side with the C-clip it has about 2mm of play. Is that normal?
1987 944S
2000 passat 1.8T wagon
Old 06-10-2004, 06:17 PM
KevinBaker's Avatar
I used all of them. FWIW I don't remember how many were in there before I took it apart.
Texas Greaseslingers-Have wrenches, will travel-Social Director?
Old 06-10-2004, 07:20 PM
SoCal Driver's Avatar
Sure a scummy looking throwout bearing for a new one.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-10-2004, 07:30 PM
I thought the new one looked a little shinny so I sanded it down and left it outside in a wet sock for a couple of days to get it "looking right". We don't want the "host car" regecting the new part.
Nah, it is my old one I had already assembled the new one and didn't feel like taking that snap-ring out (not very good with those) for the photo.
So, do I need all three? Is that amount of play (with the spring washer on the other side compressed) good?
1987 944S
Old 06-11-2004, 04:59 AM
AFJuvat's Avatar
You use as many shims as possible to eliminate play in the bearing - usually you use 2 or 3 of them.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-11-2004, 05:15 AM
"I thought the new one looked a little shinny so I sanded it down and left it outside in a wet sock for a couple of days to get it "looking right". We don't want the "host car" regecting the new part."
Ronnie - ya have the clutch going back together and ya still have a sense of humor - I'm impressed!
Old 06-17-2004, 04:36 AM
Ronnie, you get the "first time i've laughed today" award.
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 06-17-2004, 08:36 PM
88_944's Avatar
I just did my clutch job and I remember seeing 3 thin washers. I used all 3.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 06-18-2004, 01:12 AM
Send a message via AIM to shocker1322
When I did my clutch job I only needed 2 of them. I agree with AFJuvat, just use as many as you need. I looked to see the spacing on the old one and matched it. No problems yet.
'87 924S, Hawk HP Plus Pads
Centerforce clutch and pressure plate
968 M030 Front and Rear anti-sway bars
28mm Sway-Away Torsion Bars
275 lb/in hypercoils, adjustable Koni's
Old 06-18-2004, 03:48 PM
I ended up using two as with three I couldn't get the c clip in.
I tied a sock around it as a cushion for when it breaks off and bounces around the bell housing.
1987 944S
Old 06-18-2004, 05:28 PM
