StoneGrey's Avatar
My clock stopped!
This really p'd me off...... I removed my digital clock to put in a new bulb.....I was so careful removing all the parts etc etc etc.... I put the bulb in.. and the it worked perfectly..... unfortunately, the clock stopped showing the time.... now what was supposed to be quick and cheap fix, and turned out to be and expensive item on my 'To do List'.
I haven't replaced it yet and I was wondering if its fixable, I assume its the transister or one of the diodes that popped.. they seem to be the weakest....... and no, I didn't, disconnect the battery or fuse before working.... slaps slaps and more slaps.....
Any circuit diagrams out there?
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Full engine rebuild July 2007
Old 06-07-2004, 08:31 AM
adrian jaye's Avatar
is it blank ?
changing the bulb wont break anything, sounds like a loose connection with the clock out, make sure everything is pressed in and the wires when wiggled dont loose contact
HTH
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 06-07-2004, 09:29 AM
ps when I did mine, I never disconnected the fuse or battery neg !
NotJustPorsche
Old 06-07-2004, 09:30 AM
StoneGrey's Avatar
totally blank.....
I've check the wires, the contacts, pretty much everything.... out of desperation, I even totally dismantled the clock.....
I have a clock on the CD loader, but I hate little bits not quite right
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Old 06-07-2004, 12:48 PM
pokey's Avatar
Send a message via AIM to pokey
It just means your car will not get any older... the automotive equivilant of Never Never Land.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-07-2004, 01:45 PM
You said you checked everything, how about the fuse? When I took my clock out to change the bulb, the fuse blew for some reason.
Old 06-08-2004, 11:31 AM
Cover it with black electrical tape.
Old 06-08-2004, 02:11 PM
StoneGrey's Avatar
It seems I'll just have to live with it until my warchest is big enough to replace it........after I've tried to hack it back to working order not!
I figure I'll ask around the local techies here.. maybe one of them has some bright ideas......there are only about 6 components that make up the clock..... how difficualt can it be
thanks guys....
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Old 06-09-2004, 12:09 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
"If you have a working tv on top of a larger, nonworking tv, you might be a redneck."
-Jeff Foxworthy
put a larger, working clock on top if it!
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 06-09-2004, 12:13 AM
todwic's Avatar
Oh, they have a light? We talking about the digital clock? What kind of bulb does it take? How to you get the face off?
'86 951
Old 06-09-2004, 12:14 AM
Super Moderator
nize's Avatar
does anyone have instructions on how to change the clock bulb and where to buy this part? mine just went out also. is this a difficult procedure or can a novice do it?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-09-2004, 01:38 PM
Burn the fire.
Brando's Avatar
replace failed clock with eject button.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-09-2004, 01:44 PM
Kore944's Avatar
I've seen on Ebay, I think, a fuel pressure meter that looks just like your digital clock. It reminds me of the old school spectrum analysers on old stereos. Anyway, I kinda think they're a little on the cheesy side, but would probably look better than black tape. I've changed my bulb a couple of times without any problem. I even tried to get different color leds to work in it, but the colored ones aren't bright enuff to shine thru.
Old 06-09-2004, 01:54 PM
TCMdocs944's Avatar
You really want to ask the guy who broke his clock changing the bulb about this????
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-09-2004, 02:06 PM
StoneGrey's Avatar
For the guys who don't get up so early in the morning......
The S2 has a digital clock...
Changing the bulb is easy.. just don't break the dash cover in the process. I didn't do that (If you need instructions... I will post an address with very good instructions.)
Breaking the clock while fitting a bulb... well... yeah it was pretty neaderthalish of me.... way to complacent about fixing stuff I guess. I suppose it took a power spike while reconnecting the power and popped one of the components..
So techincally, my clock stopped, but actually it went blank
And lastley........ what are the odds of the clock breaking at proximately 9:44?
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Old 06-09-2004, 11:22 PM
pokey's Avatar
Quick fix, remove clock and stuff socks in the hole.
1956 Ford F250
1955 BMW R69
Old 06-10-2004, 09:42 AM
Super Moderator
nize's Avatar
i think all 944 models with the new style dash have the digital clock as standard.
i'd appreciate if you could direct me to the how-to link. thanks!
Old 06-10-2004, 11:32 AM
StoneGrey's Avatar
You can go to this site is in french, but if you search for it via google, you can translate it to english.... the pictures are pretty good, but it has a few errors. Don't forget the screws at the air con plate...., loosen them to get the rest fo the front place off. Theres is another DIY , but I can't remember it is.... Try Pelicans Tech pages.
Daily driver
89 944S2 Coupe
PowerMax Chip
Stone Grey
Aero Mirrors
Old 06-11-2004, 10:34 AM
The clock has a light? I've been driving my car for almost 10 years and my clock was never illuminated.
But you know what's strange....one day a couple of months ago the clock started slowing down. It still works but it's slow. Any idea? Could it be dirty or corroded connections?
Old 06-11-2004, 10:27 PM
todwic's Avatar
touche
'86 951
Old 06-12-2004, 12:54 PM
