-   -   Outside temp sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/167266-outside-temp-sensor.html)
arnebret 06-11-2004 11:54 AM
Outside temp sensor
My 951 has the 'climate control' option, but it isn't functioning properly. While i'm taking the car apart i noticed the outside temp sensor. I read in the factory manual the sensor should be 34k ohm for 0 degrees celcius and dropping to 10k for 25 deg. Mine is constantly giving 150 ohm. Strange? I think so, it should either be 0 or nothing at all. Somewhere there is still a connection, but the sensor isn't functioning properly. Any experience on this system?
1.2gees 06-12-2004 09:57 PM
I don't have any experience directly with this failure mode, but it sounds like a bad sensor might be the problem.
Ahmet
