how much is a 8v valve job
What should I expect to pay for a valve guide replacement for a 8v 944 engine. My local mech says between $1600-$2000. He is notoriously high priced.... but very experienced. should I shop around?
thanks
Old 06-11-2004, 10:05 PM
Texas944's Avatar
I have a friend that has a machine shop - they speciallize in race engines (we run a Blown alcohol injected BB Chev in a 62 Bel Air - runs 5 in the 1/8th and gets rebuilt at the end of each season - sofar never let go on us during the season) - anyway - he is in San Angelo Texas - I can ask him how much, that is assuming you take the head off and send to him. $1600 to $2000 - that guy is on drugs!
New guides, valve grind, head milled (not sanded) and crack tested and a head gasket set - what else would you need?
Brett, Dallas, Texas (Originally from Sydney, Australia)
1986 944, Zermatt Silver / Black Leather
1994 Full size Blazer, Midnight Blue
1989 IROC, Arrest-me-Red
1966 Corvette Roadster 427 4spd, Silver / Black
DRIVE THEM LIKE YOU JUST STOLE THEM!
Old 06-11-2004, 10:14 PM
SoCal Driver's Avatar
What makes you think your valve guides need to be replaced?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-11-2004, 10:50 PM
yeah I know what you mean. It seems a bit high to me but I didn't want to jump the gun a sound like an idiot....
I would consider pulling it off myself.
I would probably need to do the belts too while the head is off....it's been a few years (gotta check my records)
I was concerned about a strange vibration that seems to occur when the engine RPM drops after a rev of the engine...right around 2000 rpm. Wondering if it's related to the balancing shafts....maybe motor mounts....But I'm really not sure so I need to explore this and find out what's going on so I can take care of it at the same time. The car does need a tune up too so I'll start there.
If you could ask your buddy about the valve job price when you get a chance, I'd appreciate it.
thanks
Old 06-11-2004, 10:52 PM
SoCal driver
I started burning a little oil....mostly when I decelerate and a little when I accelerate hard. I had just assumed that it was rings and time for a rebuild. I brought the car to a reputable mech who advised that I do a cylinder leakage test. He did the test and said that there's no leakage in crankcase and valves are still seating ok but it seems that valve guides are worn. He said it's not uncommon for these engines to rack up 200K or even 300K miles without much engine wear but valves tend to need service before anything else.
What's your opinion? Is the valve job conclusion premature?
Old 06-11-2004, 11:09 PM
ae1969's Avatar
Send a message via ICQ to ae1969
.... I have purchased a completely rebuilt turbo head for $500 U.S and Turbo S racing head (titanium springs, and MANY MANY goodies) for $1000 U.S
YES THATS HIGHWAY ROBBERY for just rebuilding a head.
He would have to be replacing everything NEW....(valves, guides doing extensive machine work, polishing porting, and buying his wife dinner for the entire week before it costs that much.)
BUTTTT the price is right if he is pulling the head to do this..... In essence he is replacing your headgasket. How many of you have pulled your head and figured out how long it takes?
High mileage heads do well on these cars..... the guides do very well..... the valve stem seals are another issue. They crack, pop off, break etc.... You could just replace the valve stem seals.....
But it is worthwhile to pulll the head on high mileage engine mainly to freshen up the headgasket. It is more than likely on its way out....
You may as well pull it yourself .....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-12-2004, 06:44 AM
Send a message via AIM to TheCooler
I got quoted around 450 for a s2 head rebuild .....thats 16 valves buddy ..find another shop. (They are only replaced stuff that needs to be replaced...)
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 06-12-2004, 02:44 PM
Texas944's Avatar
Dangerous,
$200!
inc's crack test, bead blast, 3 angle valve job, new seats, new guides, new valve stem seals and a re-surface in the mill. In addition to this, I would also recommend a new set of valve springs, locks and lifters. If you need more info, call Mark at Winger Machine on (325) 655 8374 - tell him you spoke to Brett about the Porsche head so he knows who you are.
regards,
Brett.
Old 06-12-2004, 04:26 PM
$200 he says!!!!
Oh yeah!!! looks like the head's gonna get done this summer after all.
Thanks a bunch for your info. I am definately glad I registered here. I'll be pulling the head off myself and probably be sending off to Texas. I've never pulled the head on this car before so I'll probably be posting questions during the process. I have a couple of questions already but I'll run a search of past posts first...
I'm wondering about the engine vibrartion thing though....
"I was concerned about a strange vibration that seems to occur when the engine RPM drops after a rev of the engine...right around 2000 rpm. Wondering if it's related to the balancing shafts....maybe motor mounts....But I'm really not sure so I need to explore this and find out what's going on so I can take care of it at the same time."
Has anyone ever heard of symptoms like this before?
thanks
Eddie
Old 06-12-2004, 05:46 PM
adida(r 944)'s Avatar
is dangerous experiencing(sp?) the 944 shudder????
if so check out FR WILKS web site might be some help to you...
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 06-12-2004, 06:20 PM
Texas944's Avatar
Yeah - Mark has always looked after me - I have known him for a long time and he does the best work.
As for that vibration - I have read on past posts about the balance shaft belt and the possibility that it may have broken which would cause it - take that top cover off and have a look!
As for doing the head yourself - check out www.clarks-garage.com, and like you said, just post a question - the guys on this forum are very knowledgable and helpful (a bit of sunshine for everyone)!
Old 06-12-2004, 06:22 PM
Send a message via AIM to bluebullet
i guess you guys are lucky if the balance shaft belt breaks...cuse mitsubishi motors are designed in such a way that if it breaks, it will get caught in the timing belt and take it out with it.....experienced one of those...which is the reason that motor doesnt have balance shafts any more. I wonder if you could eliminate the balance shafts on the porsche...but a 2.5L motor is very big...compared to my 2.0...
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 06-12-2004, 06:45 PM
I read the info about the N/A shudder.....yeah well I have that problem too. Adding it to the list. Thanks "adida(r 944)"....one less mystery.
The vibration seems is something else though. It will continue as long as the RPM is in the range of 1500-2500. There doesn't seem to be any vibration above or below this range. I'm kinda suspecting Balance shaft or Balance shaft belts.....but would make sense if the vibration ceases at higher RPM?
Old 06-12-2004, 08:02 PM
could it possibly just be random stuff resonating between that rpm range and causing it?
Old 06-12-2004, 08:44 PM
AFJuvat's Avatar
I think the proce he is quoting is for the complete job - rebuilding a head shouldn't cost more than about $600 if you are replacing valves and guided and keeping the springs - the springs is where the rebuild gets procey quickly
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-12-2004, 08:49 PM
texas 944, is that guy still around and doin the valve work? I'm trying to get my 83 done and that $200 is a great price....
Old 03-23-2010, 11:54 AM
HOLY CRAP
that was me!!!
back when I was a newbie!!!!
LOL
Dude, please don't do that!!!
it's like seeing your high school photo posted on TV
no one wants to see a thread from 6 years ago
we had a chat about 8V valve job about a week ago
I feel like I'm standing in front of the guys with my pants around my ankles!!!
Old 03-23-2010, 12:14 PM
Texas944's Avatar
Dangerous,
I laughed my ass off ~ for a minute i thought i had lost the plot - i havent posted anything on the forum for a while and I was beginning to think that maybe i had posted something in my sleep or something until i looked at the post date!
Did you end up getting mark to do your head? He is still there but now he also owns a huge engineering company too?
cheers,
Brett.
Old 03-23-2010, 12:56 PM
Tex
ME TOO BROTHER!!!
I'm still chuckling
I had been away from the forum for a while too, only recently been popping back in. So here I am at work and an email pops up saying someone responded to smth on Pelican. I click on and see this post about a valve job...and I'm thinking "what idiot is going to shell out that kind of loot for valves?" Then I look at the name and my eyes popped out!!!
What the hell???? This has to be some kind of prank!!!! Then I saw the date and my heart started beating again....
I actually went ahead and did the job myself. Feels like a lifetime ago though!!! oh the nostalgia. My first timing belt tension....My first water pump R&R....(sigh)
now it's going to take another 6 years to bury this thread
Old 03-23-2010, 01:16 PM
Proprietoristicly Refined
John_AZ's Avatar
thanks
HOLY CRAP
that was me!!!
LOL
Tex
ME TOO BROTHER!!!
I'm still chuckling
Heh Heh Heh
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 03-23-2010, 03:32 PM
