84 speedometer cable
Is there an easy way to replace the speedo cable in my 84 944...????? or do I just ram my hand up under the dashboard and try to find it....
Old 06-14-2004, 11:21 AM
bearone2's Avatar
probably have to take the instrument cluster out to unscrew it from the speedo head, not sure about the other end.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-14-2004, 11:25 AM
SoCal Driver's Avatar
Have to pull the instruments unless you have really small hands and arms.
Still with the instruments out it's easier.
After you pull it out of the left front spindle tie a string to it then pull it back through the fire wall. Tie the string to the new cable and pull it through the fire wall.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-14-2004, 12:50 PM
Are there detailed instructions somewhere to pull out the instrument cluster??????
Old 06-14-2004, 02:12 PM
Try www.clarks-garage.com
If not there; you pull the steering wheel and the plastic covers on the steering column switches, remove the screws in the top of the housing and pull it out.
Old 06-14-2004, 02:40 PM
thanks guys.............
Old 06-14-2004, 02:54 PM
Send a message via AIM to 944imraan
When you install the new cable, you 'll want to screw the instrument cluster end on first, then the other end. Otherwise, you're aligning the cable and screwing it on blind, with your hand behind the instrument cluster.
Haynes manual is actually somewhat decent for this job, BTW.
White 1985/1 944
--my first car
--limited slip differential
--cross drilled rotors
--omnimagnum high-energy ignition
--CB equipped
--laptop installed, seeking GPS chip
--keep the socks away from my car
Old 06-14-2004, 04:30 PM
Don 944 LA's Avatar
pay some neighborhood kid with small hands $2 to fish it out maybe.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 06-14-2004, 07:11 PM
Used & Abused
I managed to pop out the left gauge by reaching from under the dash. I unscrewed the speedo nut, used the hole to pop out the speedo, and removed the MPG sender connector. Don"t slam the speedo out or you will break the PC board on the back of the speedo.
Don't forget the string trick as SoCal mentioned.
Good luck.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 06-14-2004, 08:27 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
I was going to reply here and try to help, but SoCal did a good job. Just take your time and you should be fine, it's not hard.
Ahmet
Cheers!
Old 06-14-2004, 08:30 PM
thanks guys.....my next weekend project
Old 06-15-2004, 03:09 AM
