Early 944 Windshield Question
Hi,
I have an 84. I'm wondering if my car is missing some rubber pieces that would possibly fit between the metal frame that holds the front windshield and the windshield itself.
Right now, I can place my fingertips in the cavity that exists between this metal frame and the windshield itself. Seems odd since this would seemingly catch a lot of wind and weather.
Regards,
DL
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 07-15-2004, 12:06 PM
entertaining the idea
UconnTim97's Avatar
That is normal...they addressed that gap with the later 944s having a flush mounted windshield. I believe you can have your next windshield flush mounted.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-15-2004, 01:26 PM
Actually, they are suppose to have a gasket in there. Both of my 84's have it, but our team track car does not, it is a 84 also. A lot of times, they start coming out and PO just pull them the rest of the way out, or the windshields get replaced and the gasket dosen't.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 07-15-2004, 07:41 PM
