1986 PORCHE 944 wheel bearing problem
Hi:
Iīve been looking for the rear wheel bearing of my 1986 944 NA, and itīs been imposible to find cause I dont have the measures or the part number.....so.....can anyone gimme that info??? I dont live in the US thatīs why I cant just go and buy these buy the car make and model.....everyone ask me for the bearing size or better yet, the part number....I know the SKF company has a wheel bearing that fits for the 944, 911,924S and 968....but I was wondering if it came on any other car makes......like audi or BMW.....any tip is helpfull THANKS
Step on it!!!! |
Single unit double race bearing Porsche part number 999 053 020 01.
Requires a keeper clip Porsche part number N 012 350 1. Don't know what the Porsche part number crosses over to.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
You can use the 33 41 1 468 903 BMW rear wheel bearing, fits nearly all BMWs from 83 and up.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
So that's where Porsche got the design from.
so... you got that supra motor in yet? got any pictures?
so.....then the 33 41 1 468 903 BMW rear wheel bearing from a will fit on my 1986 944......I hope it does......
AND YES!! finally the engine is in the car......Iīm just waiting the custom made engine mounts and a few parts that needs modification for the presure plate from the supra to fit with the clutch disc.........aaaaannnnnnnddddd.....there is room enough to use the 944 radiator and fans pluss an intercooler ....the only problem now is the suspension and the air filter cause we dont know where to put it.....ouuuu.........and the brakes-servo had to be removed.....so Iīll have to find one from other make to replace it.......thatīll be troublesome...... thanks....
Step on it!!!! |
Pictures?
Ahmet
Cheers! |
and what about the AXLES
DO YOU KNOW THE PART NUMBER FOR THE AXLE???? ALSO THE LIGHTS LIFTER AND THE HIDRAULIC PUMP
Step on it!!!! |
look it up.
Stub axle for the 86 944 : 951 332 235 01
Hub is : 951 331 067 00 Head Light Motor is : 477 941 379 B Power Steering Pump : 944 347 432 03 You can replace the CV's on the drive shafts.
THANKS!!!!!! itīll be really helpfull........this weekend Iīll take some pics to my project and post them ASP.....
Step on it!!!! |
Iīve heard that there are several parts from the 944 used also on the 911, and audi......so I was wondering if the steering pump was also used on early audi cars.........any idas?????
Step on it!!!! |
