Send a message via AIM to SlowToady
Red warning light on dash coming on?
I was out driving around today and noticed something I've never seen before. While I was driving the red warning light with the "!" came on momentairly, three times. Once while I was in 2nd gear at 2200RPM, once in thrid at 3KRPM, and again in 2nd at about 2200RPM. What the heck does this mean? It just started doing it..it seems random as I can't duplicate it intentionally. It goes on for just a second and goes off, or it blinks.
Any ideas?
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 06-16-2004, 08:45 AM
Parrothead member
VINMAN's Avatar
Could be oil pressure, brakes , brake fluid level, different # of things. check your other guages too when it comes on
Vinny
Old 06-16-2004, 09:00 AM
I'm off the hook.....
Look in the owners' manual.
Seems like that might be a shift indicator. I know that's a low RPM, but maybe unloaded, it comes on.
No, I don't sing. Based there for too long.
Old 06-16-2004, 09:27 AM
Chris_924s's Avatar
check the grounds for the dash... maybe time to clean them up.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 06-16-2004, 09:40 AM
sasquatch's Avatar
The owners manual states that the ! will come on when any other dash guage, or brake fluid level goes out of spec.
My number 1 thing to check is brake fluid level.
J
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 06-16-2004, 02:22 PM
fast924S's Avatar
Send a message via AIM to fast924S
Do you have brake pad sensors?? If so I think it sets off that light when the pads are to thin
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-16-2004, 07:30 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
I just took my bulb out...
my brake pad sensors aren't hooked up either
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 06-16-2004, 09:28 PM
ur2slo's Avatar
Had the same problem recently, the same light was blinking on a lot. Then noticed the oil pressure gauge was pinned at max... Mechanic replaced the oil pressure sending unit, and the light has not come on since. Sounds like the gauge issue might be the answer...
Dave T
89 S2 cabrio
Alpine white
89 BMW 325i, "das blau schwein"
"I'm not tailgating, you're going too slow..."
Old 06-17-2004, 02:36 AM
Well, it was the brake fluid. Oil pressure and everything else was fine, so when I took it into work to change my tranny fluid I checked everything else and my brake fluid is at the min. line. I guess that's why I wrote down "bleed brakes" on my "944 To Do List".
I got the light to stay on for a good 3 or 4 seconds (before it was a really quick flash) and a light that also said "brake fluid" came on and it kinda hit me..brake fluid.
Old 06-17-2004, 10:23 AM
Parrothead member
VINMAN's Avatar
Glad to hear it was something simple!
Vinny
Old 06-17-2004, 11:02 AM
Are you sure it isn't the blinker fluid? Might as well check it while you're in there...
Old 06-17-2004, 02:22 PM
fast924S's Avatar
what about the muffler bearings, dont they have wear sensors too
Old 06-17-2004, 05:43 PM
Isn't that a synthetic? If so, I'll have to go pick some up.
Better safe than sorry...
Old 06-17-2004, 06:50 PM
