Question Torque Specs for Wheel Spacers ???
I am installing a set of used wheel spacers with the studs and nuts, what are the torque specs to bolt them on.
Mark
'86 944NA
Old 06-16-2004, 06:01 PM
Use the same torque as the wheel nuts; 130Nm (93lb ft). You probably (if they weren't supplied) need steel wheel nuts for the spacers to hub (use the alloy nuts to hold the wheels on) as alloy wheel nuts are too tall and will not allow the wheel to fit correctly.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-17-2004, 04:19 AM
Smile
Thanks Brit, this is exactly the info I needed !!!
Mark
'86 944NA
Old 06-17-2004, 07:05 PM
