TropicalFish944's Avatar
Send a message via AIM to TropicalFish944
Power Steering Pump and Warning Light
Ok, here is the deal... when I'm in my drive way and I turn the wheel, the power steering pump grinds... I've checked the fluid levels and they are ok. And when I'm moving, as long as it's faster than a slow walk... there is no noise at all...
If anyone has any clues, help me out here... thanks
Second... whenever I come to a red light and I press in on the clutch, my rpms drop, as does my oil pressure, and we are talking to 1 or lower... and my warning light comes on... I've got oil in it (I check 2-3 times a week)...
Any clues here help me out... thanks again
Just in case it's a 85.5 944 with about 130000 on it...
Old 06-17-2004, 04:49 AM
s928s's Avatar
1. POWER STEERING: Could be a loose belt, check tension. Air in the fluid from running it low, White Pinkish foam. weak or worn pump.
2. "!" light. Is comming on because oil pressure is dropping below preset level. What weight oil are you running on a 130k mile car. Replace the pressure sensor on the oil cooler first, diphram can weaken over time. otherwise may be due to internal wear and excess clearences.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 06-17-2004, 05:23 AM
Maybe the idle speed is too low. If the engine has recently been worked on you might want to check the crank pulley bolt, if it's loose the oil pump will not work properly.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-17-2004, 08:05 AM
10w30 synth... should I be running something else?
Thanks for the tips, I'll give it a look and give an update.
Old 06-17-2004, 03:00 PM
