quick fan question
a while back my 924 turbo over heated after a short drive i was just tinkering around with it and with the key off , i pulled the leads off the temp switch at the radiator and jumped them and only the left fan came on . Is the way it is supposed to be or should both come on.
Thanks,
Gary
1982 924 Turbo
Old 06-22-2004, 04:43 PM
SoCal Driver's Avatar
Both fans run with the AC on. Think the AC relay over rides the temp switch and thus the other relay much like the early 944's.
for some strange reason both fans on my car run with out the AC on.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-22-2004, 06:08 PM
No a/c previous owner took it out
1982 924 Turbo
Old 06-22-2004, 06:33 PM
Thanks,
So one fan running after I shut the car off isn't enough to cool off the car without it overheating ?
Thats what happened last week. I started it up and let it run for awhile while I took some "before" pics and then drove it to the car wash 4 blocks away. Left it running while I hosed it off, drove 4 blocks home and shut it off. A few minutes later there is steam from under the hood and antifreeze all over the garage floor.
Thanks again,
Gary
1982 924 Turbo
Old 06-22-2004, 06:54 PM
ignition was off . Thanks for all the help !
1982 924 Turbo
Old 06-22-2004, 07:44 PM
ok , tested the fans and they worked . hooked back up to the thermo switch, took for a short drive , nothing hard. Came back and let it idle for a minute while i got out to see if the fans would come on . They didn't and it overheated .
Thermo switch replacing time ?
I have only had it for a month and the PO said he did not have this problem. But he did replace the thermostat some time back and a couple of hoses.
Thanks,
Gary
1982 924 Turbo
Old 06-24-2004, 06:19 PM
bearone2's Avatar
Cool
me too but then i thought they were both supposed to be on.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-24-2004, 06:42 PM
no a/c a PO took it out
Thanks FR
1982 924 Turbo
Old 06-24-2004, 06:53 PM
yup still have two fans
1982 924 Turbo
Old 06-24-2004, 07:03 PM
