Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
New Enxhuast? no longer have to pass emissions
this may seem like a newbie question, but I'm gonna ask anyway. I no longer have to pass emissions in Connecticut because my car is over 20 years old. My car is approaching the point where i might want to think about refreshing some of the exhaust bits.
So here are my questions:
1) Would there be any performance benefit to completely eliminating the catalytic converter and going for a "test pipe"? I know it is listed in the parts catalogs as an upgrade, but due to backpressure, etc, might one actually LOSE performance by eliminating the cat?
2) If one WERE to go the test-pipe route, I know the resultant car would be much louder than a stock one. Is there any way to keep things on the quiet side?
3) If I WERE to go a test-pipe kind of route, would it be an added advantage to upgrade the headers? People don't seem too impressed with Bursch, but B&B has gone over well
4) I guess my main question is: without emissions being an issue, what would be the most effective exhaust setup?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 06-20-2004, 06:24 AM
fast924S's Avatar
Send a message via AIM to fast924S
If I where you, First get the header, I noticed it made a good difference in torque down low and more HP up in the R's, Also if you can get a header rap kit, this will help keep temps down in the engine bay. As for running with out a cat, I am doing that now and yes it is louder but I like it. If you can get a good cat-back exhaust system with a good resenator then you should be ok. Another thing you can do is remove the old cat and punch out the material inside and reinstall This will help reduce some noise because of the big empty chamber. I havent done any Dyno tests but I did not notice any power losses from removing my car. Backpressure would only be a problem if you made the DIA. of the exhaust greater then 2.5 inches. Good luck and let me know how it goes
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-20-2004, 06:49 AM
Send a message via AIM to bluebullet
the worst thing you could do is punch the cat out and hollow it. it will hurt performance a slight bit. The exhaust gases expand into the hollow chamber, which slows them down (bigger diameter) and they cool down, then have to cram back into the exhaust pipe to get out the. I done extensive dyno testing on that, and on the street. Using a hollowed out cat just makes the car sound crappy (my work van sounds like that because ours got clogged and we punched it out cuse we were cheap, and it runs like crap now). Your best bet would be to build your own exhaust, using 2.25 or 2.5" mandrel bent piping all the way, with a long magnaflow resonator in the middle to keep things quiet...
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 06-20-2004, 09:43 AM
Send a message via AIM to TheCooler
SFR looks good. Expensive but good ... http://www.speedforceracing.com/modindex.html
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 06-20-2004, 09:55 AM
SoCal Driver's Avatar
Header rap? Is that like Gangsta rap?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-20-2004, 10:29 AM
Writer/Teacher
CJFusco's Avatar
i'm about to sound really ignorant, but can one define for me exactly what "cat-back" means?
Old 06-20-2004, 07:04 PM
fast924S's Avatar
Cat-back means, From the cat back.
Old 06-20-2004, 07:24 PM
Writer/Teacher
CJFusco's Avatar
okay... well duh. But what I mean is, does "cat-back" include the cat? If you bought the SFR 2.5" or 3" cat-back exhaust, would you still have a catalytic converter?
Old 06-20-2004, 07:30 PM
fast924S's Avatar
Ok sorry, Cat back means from then end of your stock cat back. SO if you went and got a cat-back system it WOULD NOT come with a cat. Its all the piping after the cat.
Old 06-20-2004, 07:33 PM
Writer/Teacher
CJFusco's Avatar
what would have to be done to eliminate the cat? Just buy a resonator with the new cat-back system? There don't seem to be too many systems for sale that run right from the header to the rear of the car
Old 06-20-2004, 07:38 PM
fast924S's Avatar
Well you could go and get a High flow universal cat or get a Test pipe. Most cat back system have a resonator installed in the piping
Old 06-20-2004, 07:54 PM
Send a message via AIM to Trevor
I have an aftermarket exhaust on my car and I would like to go back to stock. If you would like to sell your muffler to me let me know.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 06-20-2004, 08:06 PM
