-   -   will not start (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/168645-will-not-start.html)
explosion242 06-21-2004 02:17 AM
will not start
I have a 85.5 944 and I started having problems with it starting. I have a new battery in and it will not crank. Is it the starter or maybe something else?
SoCal Driver 06-21-2004 04:49 AM
Need more information.
Will not crank = engine will not turn over at all and there is no noise or action by the starter.
explosion242 06-21-2004 11:44 AM
Yeah, there is a noise like something is getting power to it, but no cranking at all. The car started to do this and then it would start, then after about a week and a half of this going on, it quit starting all together.
mambodave 06-21-2004 11:48 AM
if its clicking, it could be bad battery...or starter is draining your new bat??????
explosion242 06-21-2004 11:56 AM
I don't here any clicking noise though.....
Brando 06-21-2004 12:46 PM
If the starter is functioning, you'd hear a loud click when you crank the key to start. That's the solenoid on the starter providing power to the starter. If you don't hear the click of the solenoid, I'd say take the starter off and bench test it.
Imwithstupid^ 06-21-2004 01:48 PM
find your starter relay. Remove it. Make sure the car is out of gear. run a wire form the batter and touch it to the pin that feeds the starter power.
If it turns over your problem lies in your ignition.
If you hear a click but doesnt turn over your problem lies in the starter armature.
If you dont hear a click your problem lies in the starter solenoid
I wired in a push button start in this manner in my previous car that had a bad nuetral safety switch. I am currently doing this to my 944. It's going right where the cigarrette lighter is. It just seemed like a cool place to put one. I will be using the cig ligeter as the button of course. It might seem ricey, but it's nice not to have to push the clutch in all the time to start your car, especially when it's cold and you are shivering in your leather seats. you do still need the key turned forward, but that can be bipassed.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
