'83 944 Rear Wheel Stud Replacement
I'm sorta helping a friend to replace a rear wheel stud (I instruct, he gets dirty and grunts. Due to the stud length, it seems like the hub has to be un-bolted to provide enough clearance. Is this correct, or is there a "trick" I'm missing?
Thanks,
Brad
Old 06-21-2004, 10:42 AM
SoCal Driver's Avatar
Possibly. Be sure to torque it back to 350 ft lbs and put a decent cotter key back in it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-21-2004, 10:55 AM
I'm not talking about the stub-shaft nut, but rather the four bolts that fasten the bearing carrier. I am assuming that if these four are unbolted I'll get enough play to move the assembly around and provide enough clearance - yes, no, maybe???
Brad
Old 06-21-2004, 11:03 AM
You may ruin the seal. Give it a try.
Old 06-21-2004, 11:10 AM
