entertaining the idea
UconnTim97's Avatar
6 Blade fan question.
I just replaced my failing 3 blade fan on the passenger side with a 6 blade fan. When the fan is on it looks like the fan is making contact with the lower radiator hose going to the water pump. Whats the best and easiest way to fix this?
I'd rather not remove the whole assembly again and switch the 6 blade fan to the driver's side. Getting the shroud back in was quite the PITA.
Thanks....
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 06-21-2004, 04:41 PM
Granite 944's Avatar
This is an excerpt from TSB # 8526, dated Dec. 6, 1985.
"Replacement of 3 blade fan with new 6 blade fan:
-Disconnect battery -Remove engine splash shield -Drain coolant -Replace coolant hose to water pump. This hose has a different shape and guarantees a safe distance of at least 10 mm between the new fan blades and coolant hose. If a new hose is not available, the old hose must be shortened by 5 to 10 mm on the waterpump side. -Refill coolant -Remove fan shroud and replace fan/motor -Reinstall fan shroud Note: Check installed position of fan! Plug connection must face down at an angle to the right."
The next time you do buy a lower radiator hose, I'm sure you will be getting the "newer" shaped hose. You might be able to just tie the hose back for now.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 06-21-2004, 04:54 PM
UconnTim97's Avatar
Thanks for the quick reply. I just checked, the fan isn't hitting the hose, but there is about 2mm of clearance. I try cutting the hose tomorrow.
Old 06-21-2004, 05:07 PM
TCMdocs944's Avatar
Zip tie
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-21-2004, 05:44 PM
SoCal Driver's Avatar
Swap the fans.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-21-2004, 07:48 PM
UconnTim97's Avatar
Ok, I removed the hose and cut about 5mm off of it. It worked great, there is a good 10mm between the fan blades and the hose now. I figured, I was planning on changing the coolant this week anyways.
Old 06-22-2004, 04:15 PM
TCMdocs944's Avatar
That'll work too.
Old 06-22-2004, 06:38 PM
Send a message via AIM to bluebullet
mine came with 6 blade fans already....i dont even hear them turn on they are sooo quiet...
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 06-22-2004, 07:47 PM
TCMdocs944's Avatar
I changed mine to an aftermarket 'flexlight' assembly. Takes a little work to make it fit but it works very, very well....bout $90.
Old 06-23-2004, 06:37 AM
bearone2's Avatar
i paid $75 for the pair /shroud thru this forum, bolted them up without any clearance problems.
seems to be a clearance problem when putting the 6 bl in the 3 bl hole.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 06-24-2004, 12:32 PM
does the 6 blade assembly have a different shroud than the 3?
I have the 3 blades installed and a2 6 blade motors.
Was going to do teh swap, but after reading this post, it sounds as if the shroud is different??
Current: 1973 914/4 project. FOR SALE
Old 06-24-2004, 12:54 PM
bearone2's Avatar
dimensionally the shrouds were the same but the fans/holes were different sizes as i remember but i have no way to compare them now.
Old 06-24-2004, 01:01 PM
The shrouds are the same. The lower hose is different. The hose that was on the 86 that I got the six bladed fans off of has a much smaller diameter as it passes the fans. Also has a heavy rubber sheath on it.
Old 06-24-2004, 03:12 PM
Ah...I see
Old 06-24-2004, 03:23 PM
TCMdocs944's Avatar
I used the stock shroud and ditched the flexlight one.
Old 06-24-2004, 04:57 PM
