-   -   Damn, how can I remove this?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/169652-damn-how-can-i-remove.html)
Manute 06-27-2004 05:15 AM
Hi!
I´m stupid, I was boring, playing with fingers pushing here and there and the button cover next to the A/C switch fell off.
I tried to catch it, but seems imposible, so now....how the hell can I remove the entire cover to take it??
http://forums.pelicanparts.com/uploa...1088338516.jpg
rachwalj 06-27-2004 05:30 AM
Pull out the casette / wallet / other holder below the radio and reach in there and grab it.
Mine pops out pretty easily.
ronniebaldino 06-27-2004 08:06 AM
I think if you pull out the ashtray there are screws under there. Others are behind the storage hole under your radio??? I don't remember exactly but if you poke around a bit you will find the screws. The shift boot will come out if you pry around the bottom.
ronniebaldino 06-27-2004 08:08 AM
Now that I think about it if you pull out that storage unit thing and the shift boot up you should be able to get it one way or the other without taking off the panel.
Manute 06-28-2004 10:01 AM
Yes, there are two screws in the ashtray, now I need to remove the other side; so how can I pull out the storage unit, just pulling it?I dont wanna brake anything.
Thank you, very useful!
will944 06-28-2004 10:04 AM
Yup...the storage unit will slide out....I always apply pressure downward with my hand in it....then just pull back towards myself
ronniebaldino 06-28-2004 05:02 PM
Ditto, should be able to pull it out with a little wigling.
ronin 06-28-2004 05:27 PM
damned spaniards!
