seaboltman's Avatar
Ratteling when I take out the clutch
When im ideling, and i let the clutch out, I hear a ratteling sound. Im assuming it would be the clutch making the sound. Wondering what I need to do.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 07-29-2003, 06:19 PM
Could be the rubber coming apart, or throw out bearing starting to go bad. Have you put in a new clutch lately?
drew1
drew1
wife has 924 turbo
Old 07-29-2003, 06:41 PM
seaboltman's Avatar
the previous owner changed the clutch not to long ago.
Old 07-29-2003, 06:42 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Put her on stands and get someone to go under the car as you go through the gears.
It could be something simple.............. although it sounds like it could be any part of your drive line.
My guess would of been your throw out bearing but you would hope a new one was replaced by the previous owner.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-29-2003, 06:54 PM
seaboltman's Avatar
if its a throw out bearing, how much am i looking at?
Old 07-29-2003, 07:57 PM
MrPants's Avatar
a ton.
throw out bearing its self is prolly not more than $100. but labor is gonna cost you. some people on the boards have done clutch work themselves so it is possible. but you may want to schedule a weekend (or more) of full work days if you take that route.
84 944 Non Alcoholic
Old 07-29-2003, 08:06 PM
seaboltman's Avatar
Clearly a time for an Unhappy smiley face.
Old 07-29-2003, 08:21 PM
MrPants's Avatar
i dont mean bear the bearer of bad news.
it could be some thing unrelated to the clutch. maybe just a rattling bolt on one of the exhaust hangers. have it checked out.
Old 07-29-2003, 08:54 PM
seaboltman's Avatar
if it was unrelated to the clutch, would it still rattle Only when the clutch was out?
Old 07-29-2003, 09:05 PM
A throw out bearing would rattle with the pedal down, being mashed down, or being let up. A good thing to do would be follow advice on previous post, put her on jack stands & check her out.
drew1
Old 07-29-2003, 09:26 PM
MrPants's Avatar
i assumed that by "let out the clutch" you mean let out the clutch pedal, as is engage the clutch, yes? if that is so everything back to the transmission would be spinning, possibly causing some vibration of parts in the vicinity.
if the car is out of gear with the clutch out, and you rev it does the rattling change at all?
Old 07-30-2003, 01:09 AM
bertman's Avatar
Don't panic yet. These cars are often noisy while idling, clutch desengaged in neutral. Unless this is a new "problem", the noise is likely routine and nothing to worry about unduly.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 07-30-2003, 06:15 AM
sasquatch's Avatar
Do not worry. The symptom you describe has been in both Porsches. It lies in the reverse idler shaft within the transmission. After years they like to rattle. My 82 924 rattled bad at 150k miles, now at over 300k miles (with a friend of mine who is the owner now) it still rattles but works just fine.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 07-30-2003, 07:27 AM
seaboltman's Avatar
ooo, good news sas, thanks. The car is in Neutral, and it DOES not make the sound when i press the pedal down. Only when im not pressing the clutch pedal. If that helps or changes anything let me know.
Old 07-30-2003, 07:40 AM
sasquatch's Avatar
Nope that is it. When the shafts in the transmission are spinning (clutch out) in neutral. Rattle rattle rattle. Yup, it is fairly normal.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 07-30-2003, 07:43 AM
seaboltman's Avatar
awesome, thanks. Im still gonna have a look either way just to be safe, but im at ease now.
Old 07-30-2003, 08:03 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
I have sort-of the same problem.
Whenever I let off the clutch after a shift and get on the pedal hard, I hear a "rattle" that sounds like someone shaking a can full of paint chips, it's very faint. It seems to be coming from the back.
I recently had my CV's repacked and thought perhaps the sound had something to do with that. The sound I'm getting is almost like a very quiet version of the noise bad CV's make, but more "tinny" than "solid metaly" - if that makes sense.
I know when you let the car idle with the cluch out, there is a rattle - maybe the rattle after shifting is an extension of this sound (the fifth-gear rattle)??
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 07-30-2003, 08:32 AM
seaboltman's Avatar
where as your sound seems to be comming from the back, mine seems to be comming from the front. curious... hum Further research required.
Old 07-30-2003, 08:59 AM
vott does ziss do?
ronin's Avatar
now, I know this is going to sounds silly, but when we're talking about the R&P, we're definitely talking about a solid clunking sound instead of a clank, right?? I've had this really obnoxious clanking sound emanating from the rear of the car that I just can't isolate. it sounds much more like a loose metal plate or something where I would assume that an R&P would make a more subdued clunk (like it's inside of a solid object - the tranny - that muffles the sound) right?? right fellas??? yes???
Old 07-30-2003, 09:06 AM
ronin - you now have one post for every day of the year!!!!
I would agree that the R&P "should" make a more solid, muffled sound. What you may be hearing could be the CV joints. They give off a really "clanky" noise.
Another thought - would a bad CAT give off the sound I'm hearing? Would it rattle all the time, or just under heavier pedal play after a shift?
944S Boyeee
75,000 klms
Old 07-30-2003, 09:51 AM
