-   -   Its Baaaaaaack! Creative Engineering Part II (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/170105-its-baaaaaaack-creative-engineering-part-ii.html)
AFJuvat 06-29-2004 04:06 PM
The car has returned.......
Complaints are:
Tension, but do not replace timing belt
AC not working
Instrument cluster not working - if it is a fuse, fix it, otherwise, don't bother.
Window still not working - do not fix unless it is causing the problem with the instrument cluster
Volt meter not working - do not fix unless this is causing said problem with instrument cluster
Top off automatic transmission - fix severe leak as long as it is not expensive.
Expect much hillarity and buffoonery to ensue
For background reading, go here....
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/139717-creative-engineering-its-finest.html?highlight=Socks
AFJuvat
bryanthompson 06-29-2004 04:15 PM
It's hard to find socks small enough to fit into the fuse slots. besides, socks don't seem to conduct well.
fast924S 06-29-2004 04:19 PM
Top off automatic transmission - fix severe leak as long as it is not expensive. :D :D :D :D :D :rolleyes:
TCMdocs944 06-29-2004 04:31 PM
My socks bleed for that car. It is really so sad.
I have been helping an aquaintance get his 'bargain' 944 going.
I went over the other day because I saw it hadn't moved in a few weeks. He was under the hood 'jumping' various electical point with lamp cord.
He had rigged the one fan (other sitting in the dirt) by jumping a dangling relay at the drivers footwell.
The front hoses were being kept in place with shoestrings (I offered zip ties)
Lamp cord was everywhere....holding this and that together..
loose and missing bolts everywhere.....
What can you say to someone like that?
arnebret 06-29-2004 04:32 PM
Haha, brilliant :) But still, it's just proof of what the guys at Porsche do when they design and develop cars. The things just keep going, even if you bodge it together with a set of socks. I also found some things that would 100% sure stop a lot of the other cars around to grinding halt, but somehow not the old 951. Even a completly busted rotor that damaged the distribution cap severly was no reason to stop going strong for miles and miles without the driver noticing. Only after doing a simple 'tune-up' i noticed the complete ignition system needed to be replaced (spraks, rotor, distributor and even the wires). Also, it seems that completly rusted starter motors can still crank a 951 to live without a glitch. After getting a new one, the thing still starts as nice as it always did, but somehow the crunchy noise is gone ;)
Fact is: great cars, clever engineering, robust materials = nightmare for amateur mech... (or what some refer to as a GREAT car).
Don 944 LA 06-29-2004 07:30 PM
Did you ask him what brand and style of socks would he like installed.. and should you replace the existing socks ( if they are causing a "serious" problem of course )
Ohhhhhhh, chompin at the bit to hear what this episode of " Sock Man " has instore..
:D
Roger Hall 06-29-2004 07:37 PM
my car is broken but dont fix it hehehehe
Blackfoot 06-29-2004 07:39 PM
Mike, how long would you guess it would take to determine where there is a current drain in a 928? This drain is only an issue when the car is NOT running, just sitting draining the battery. Are there many things that could be draining juice, or just a handfull?
_______________________
Cars
AFJuvat 06-29-2004 07:48 PM
First thing to find out is how much current is getting pulled while the car is sitting there - it should be fractions of an amp. Anything more than that, and it can get tedious to check - my comments about 3 - 4 kilometers of wiring in the car was not put in there for humorous effect.
I would start witht he unfused circuits first - alternator, starter, and ignition, and then work your way up from there. Depending on how much is getting pulled from the battery, you can judge which circuits to check first - if it is less than 5 amps, you start with the 5 and 8 amp curcuits.
any 928 electrical problem can be a bigger to track
AFJuvat
SoCal Driver 06-29-2004 09:57 PM
Bugger. You misspelled the 'u'. Looked like an 'i'.
Texas944 06-29-2004 11:09 PM
could be he meant a bigger bugger..??
ronin 06-30-2004 01:15 AM
qwertyuiop
ronin 06-30-2004 01:16 AM
you don't. you take them out back and shoot them
Porsche-O-Phile 06-30-2004 06:52 AM
I'm always partial to having a couple of my buddies from the APLL (Abused Porsche Liberation League) free them of their car and then take 'em into a back alley somewhere for a lesson in respect from some black rubber hoses and socks filled with gravel.
:D
TCMdocs944 06-30-2004 11:15 AM
You see....
I still hope to buy that car (or AFJ's 928 nightmare) for a song.
I just hope it isn't too messed up by that time.
Yes, I am a glutton for punishment.
nige944 06-30-2004 02:28 PM
AF,
They have some spare parts on Ebay for you
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=10408&item=2481502 742&rd=1&ssPageName=WDVW
Nige.
bryanthompson 06-30-2004 03:49 PM
You see....
heh, hmm,... and I was about to ask about AF's 928. I guess that answers that question.
AFJuvat 06-30-2004 04:33 PM
It is for sale - send in your offers
Just readjusted the timing belt today.
Has a few small oil leaks, tranny leaks, ac not working all that well, interior could use some recovering and some parts.
AFJuvat
TCMdocs944 06-30-2004 07:07 PM
$1000 - Pick it up on sunday! :)
(probably won't even cover your repairs!)
Porsche-O-Phile 06-30-2004 07:51 PM
I'll buy it just to liberate it - for a thousand bucks fine!
