Send a message via AIM to Trevor
Stereo Wiring
I'm trying to wire a Blaupunkt Honolulu into my 86 944. The last installation was a total hack job so I'm trying to sort it all out and I'm left with a few questions:
In one "harness"
2 Brown Wires (Grounds)
3 Red w/Black wires ?
2 Green ?
1 Red w/White (Ignition starter?)
The remaining eight wires, I figure are speaker wires and I can sort that out myself. Any help is greatly appreciated. -Trevor
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 07-01-2004, 04:37 PM
SoCal Driver's Avatar
Do a search. A diagram listing wire colors has been posted recently.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-01-2004, 05:55 PM
I have been looking both here and on rennlist, probably gone through 40 threads, I guess I'll try again. Thanks.
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Old 07-01-2004, 06:46 PM
Wish I could help you as I rewired recently but apparently the early wiring is totally different..If all else fails (as it did for me) get a voltmeter and start checking different scenarios. For example, you should find a constant 12V (goes to power lead on head unit), a switched 12V (remember "switched" means KEY IN IGNITION, not turned) that goes to the ignition lead, the antenna should be pretty evident unless PO took the crimp off...Good luck with the rest of them!
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 07-01-2004, 07:07 PM
Thanks for your help, looks like I'll be buying a voltmeter.
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Old 07-01-2004, 07:42 PM
Don 944 LA's Avatar
Just get one of those $2 pencil looking things that light up with 12 Volts., they have a wire with an alligator clip....
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-01-2004, 08:16 PM
i think the red/white is the "always on."
does your stereo use the fader thing? i bypassed mine so im not sure i can help there.
wish i could help more but its been like 2 years since i installed mine, and im out of town so i cant look..
good luck.
Old 07-01-2004, 09:23 PM
Great, so is the "always on" the "constant power" wire? My fader was bypassed when the P.O. put a pioneer unit in. This thing was so botched before it is extra confusing trying to sort all of this out. I appreciate the help.
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Old 07-01-2004, 09:29 PM
Here is one for the early 944's:
I'll try to find one for the later.
Old 07-02-2004, 07:45 AM
Later radio diagrams:
Old 07-02-2004, 08:08 AM
Thanks Socal, this should help.
96' Jetta (RIP)
1986 N/A (Sold)
1993 325is
Old 07-02-2004, 10:19 AM
