-   -   CAT Bypass Test Pipe? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/171335-cat-bypass-test-pipe.html)
COLDBASS 07-07-2004 04:46 PM
Anyone have any experience with one of these on an NA...its just that my current exhaust sounds anemic and I was considering a Bursch. Our host PP indicated that they dont have a Bursch for an '86 (Perf Prods does, sorry Wayne...), however, PP did say that I could purchase a GHL for $317 +...dont know if I want to spend that much only to later decide I dont like it...any suggestions?
bertman 07-07-2004 05:56 PM
I've used a Bursch test pipe with the Bursch header on an NA for many years. I don't think it does anything particularly good for exhaust sounds. If anything, the sound, with header/test pipe & OE muffler, is tinny and whooshy, if you know what I mean. Exhaust note may be different/better with just the test pipe and stock header or with a free flow muffler, I'm not sure.
However, if you can live with the sound, the Bursch system might actually improve performance a little on your NA, complementing the cam and compression increases for a little more punch at higher rev's.
fast924S 07-07-2004 07:07 PM
Im running a Bursch Header and test pipe with a B&B catback exhaust on my 87 924S, I like the way it sounds, throaty at low RPM and up around 4500-6500 it sounds like a F-1 car kinda cool, I havent had any problems with it and I noticed a torque increase threw the RPM range, I think it also helped with my other mods. Let me know if you have any questions
COLDBASS 07-12-2004 06:40 AM
Alright,
I went for it. Had the cat replaced with a test pipe (the car is being used for off-road porpoises only ;) ).
I like the low rumble. Is this possible, it seems to rev a little quicker???? Maybe the CAT was constipated?...
I like it...
When is the next So Cal meet? I'd like to compare it or at least get some objective, first-hand, onsite, opinions from some fellow owners...(this excludes YOU Ronin, unless YOU are planning to come down here so that my pet can give you a good ole fashioned Llama azz whuppin...):D :D
Bob
chitown944 07-12-2004 08:44 AM
im running the bursch headers as well...with the test pipe my car sounded like a sick cow and was too loud...almost ricey annoying so i had the cat put back on...dunno if because the cats bad or the mufflers bad...when i get my stainless catback ill put the test pipe back on and see if i like the sound...
ronin 07-13-2004 01:44 AM
Originally posted by COLDBASS
Alright,
I like it...
Bob
oh, you name the time and place, and I'll be there to face off with that dromedary wannabe once and for all. but you had better bring yer spitoon
and what's with you suddenly dissin' porpoises. you got a problem with seaborne mammals? well do ya?!?
and shame on you for using a test pipe for noise instead of performance. tsk tsk ;) I've been thinking of going the test pipe route myself once I start doing performance mods. the noise shouldn't change much due to the turbo
