Send a message via AIM to shocker1322
Oil Pressure
I noticed today on the way to class my oil pressure was low at idle. Sitting at construction the pressure was at 1. The pressure is good all the way through the revs, 2 at 1200, 3 at 2000, 3.5 at 3000, and 4 at 5000. Should I tap the gas every ten seconds or so to get oil to the lifters or is 1 good enough. I am running synthetic so I know the pressure will be a little lower, but this worries me a bit. Any advice would be great, thanks!
'87 924S, Hawk HP Plus Pads
Centerforce clutch and pressure plate
968 M030 Front and Rear anti-sway bars
28mm Sway-Away Torsion Bars
275 lb/in hypercoils, adjustable Koni's
Old 07-07-2004, 06:49 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
mine does the exact same thing, i'm running quaker state 10W30. On really really hot days (95+) when I come to a stop and take it out of gear to brake, the pressure bounces down to one and the light flashes for a second. Not sure if that's normal, scares the crap out of me though.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-07-2004, 07:07 AM
Move up to a heavier oil during the summer. I use 15-50. 5 at idle cold, 2.something at idle hot, 5 at speed.
Of course, 95 out here would be "Cool today, ain't it?" kind of weather..
Bob S. former owner of a 1984 silver 944
Old 07-07-2004, 10:32 AM
bull4u2me's Avatar
Crap, I thought that was just with my car!
~85.5 Bronze Beauty! (944 N/a Auto)
Old 07-07-2004, 03:16 PM
P944GUY's Avatar
I use Castrol 20W50, it's only 110 here in Arizona
Old 07-08-2004, 08:42 AM
Don 944 LA's Avatar
I didn't see you say that you had checked the oil level, that would be the first thing..
If you have sufficient oil, switch to 15W-50 Mobile 1. I can be 2.5 qts low and I will still show good pressure. With the thin stuff, 1/2 qt low would cause all sorts of odd readings..
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-08-2004, 09:18 PM
I confess... Phoenix is usually hotter than Tucson........5 to 7 degrees in the Summer, more of a variation in the winter
And bigger
And more crowded- reminds me more and more of LA
Fewer places to wind 'er up and let 'er go-the countryside is disappearing all the way to Cave Creek and beyond now.....
But with more sports and more good restaurants.
In spite of all that it beats the %@$# out of upstate New York!!
Old 07-08-2004, 09:47 PM
my avg consumption is 1/2qt every 300 miles, and I check it almost every day. is that about normal?
Old 07-08-2004, 09:50 PM
Don 944 LA's Avatar
Thats what I go through with a serious leak.. I drive 350+ a day and throw in a qt of Mobile 15w50 every other day..
before I had the massive leake, it would be about a qt a month, however, I didn't really drive but 5 miles a day at that time.
Old 07-08-2004, 11:19 PM
I use 10W30 Mobile 1. Like Bryan I check mine every day, that is completely normal. I also carry an extra quart around with me just in case. My level is always good. In PA it does not get that hot, I do not think we have had a day of 90 degrees yet. I might put in a heavier oil if this keeps up, this is the first time I have noticed it though.
Old 07-09-2004, 08:05 AM
