control arms and spring rates
what effect does it have on the control arms as you increase the coil spring rates?
Dave
86 944na
Old 07-12-2004, 08:57 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
rates don't matter much, ride height does
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 07-12-2004, 09:03 PM
Stiffer springs are usually shorter, thus the change in ride height. There are several 'kits' that have an adjustable spring perch. However, many of these still result in about a 1" drop in the front end, even with the perch adjusted up all the way.
FWIW...original springs on the front were about 165 lb. Many AutoX change to 200 - 250 lb springs. Not to much difference in normal street driving, but does reduce nose dive on the track. Racer's change to 400 - 600 lb. springs, which are to stiff for street application.
The contrl arm is usually not effected untill you combine very stiff race springs and bigger anti-sway bars. I have seen one of the 944Cup cars snap the A-Arm at the pivot point on the cross member...but they had BIG springs and BIG sway bars.
Good luck.
JM
Old 07-13-2004, 04:11 AM
tifosiman's Avatar
Good luck.
JM
I must respectfully disagree on the point about 400lbs being too stiff for the street. That is the rate that I am running and it is not bad at all, there is not much of a ride quality change from the 250 to the 400.
If you lower the car, you have less of a chance of messing up the a-arm if you increase the spring rate. If you lower the car and leave the stock springs in there, there is more of a chance of the ball-joint smacking the outside of the aluminum socket and breaking it out.
Just some observations from personal experience.
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 07-13-2004, 06:24 AM
