Don 944 LA's Avatar
A/C short belt ????? HELP !!!!!
OK, I need my AC
I was doing the conversion to 134 ( the cheap way ) and The low side being on the compressor eliminates any way to put on the new fitting..
I HAVE the 90 degree fitting, but it is my understanding that there is a SHORTER AC belt that allows a different placement of the compressor allowing the fitting to go on.
The trouble is that I have no idea what part # the belt is, or how much shorter it needs to be
Can anyone help me here ????
It's an early 944
I drove around LA, OC, & San Diego today ( 340 miles ) mostly stop & go with NO AC.. I have to put the AC on to kick in the 2nd fan..
Also, a NAPA part # would be great ...
Thanks again, Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-14-2004, 01:19 AM
s928s's Avatar
i am not firmilliar with an exact number, but if you have a patient parts person there is a solution. Loosen the compressor and swing it to the shortest possible belt position. take a tape and measure the path of the belt. ( best to use a fabric one or a piece of twine) note the measuement in milimeters and inches, also note how many grooves are on the pullies. Most belts are referenced by part number and length. Take the mesurements and the old belt to "napa" and compare the measurments to stock belts i beliebve they have a cross reference for the measurments to the belt. Find one slightly larger than what you measured but smaller than the origonal. I did it this way on my 928 when i deleted the air pump. I hope this helps
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 07-14-2004, 04:07 AM
Carroll Laird's Avatar
mattdavis11 posted these napa links a while back:
Short belt: http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539275&prmenbr=5806
Original belt: http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539279&prmenbr=5806
Hope this helps
Carroll
'89 S2
Old 07-14-2004, 05:13 AM
Just thinking out loud
mattdavis11's Avatar
on the other board too per your request. Works like a champ!
91 FJ80
84 Ram Charger
Old 07-14-2004, 06:40 AM
Don you have PM.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 07-14-2004, 08:41 AM
