Question backfire
problem: i'm getting backfire through fuel distributar, what is causing this,also won't stat when i turn her over the starter turns
then stops then turns over, then i crank her over, and after a bout
six revs she backfires. whats happening?
Old 07-15-2004, 03:02 AM
Assuming that you have a 924 (the 944 doesn't have a fuel distributor), I would guess that your ignition timing is incorrect. You are sending a spark to the plug while the intake valve is open.
You also may have a camshaft timing problem.
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 07-15-2004, 03:13 AM
thanks 944 ECOLOGY: WELL MY TIMING IS RIGHT ON THE MONEY!
AND IF IT WASN' T I'LD BE GETTING BACKFIRE THRU THE MUFFLER.
SOMEONE TOLD ME THAT IT MAY BE A STUCK TAPPET? DO YOU KNOW ANYTHING ABOUT THIS PROBLEM? IF SO PLEASE HELP! I
WANT MY BABY ON THE ROAD!!!!!!!!!!!!!!!!!! THANKS JON
Old 07-15-2004, 06:43 PM
naw man....check your rotor...as in cap and rotor....trust me Lemme know what happens and if the set screw is still there
If you don't live life on the edge, you take up too much space.
Old 07-15-2004, 08:13 PM
very worn 944: thanx will pick up a new one tomorrow! i'll let you know
what happens.
Old 07-16-2004, 06:18 PM
TO: VERY WORN 944. WELL, I WENT OUT TODAY, BOUGHT A NEW CAP
AND ROTOR, AND GUESS WHAT?!!!!!! IT DIDN'T WORK. STILL BACKFIRES THROGH THE FUEL DISTRIBUTOR. NOW WHAT SHOULD I DO
DAMM, I JUST THOUGHT OF IT!!!! I HAVE A SPARE GALLON OF GAS IN THE BACK!!!!!
Old 07-17-2004, 08:49 PM
