bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
ack! oil pressure oddities starting up
For the last couple days my oil pressure has been extremely high (4.5 to 5 bars) until warmed up, then very low out-of-gear at a stop when running normally.
I started noting my oil usage more closely in the last week. Very little consumption whatsoever after 400 miles. I may have overestimated my previous usage at 1qt/600 miles. I need to watch it more closely.
Anyway, i just ordered some things for a tune up (plugs, filters, all that good stuff) and will be having my coolant flushed quick-like. And am about to put 10w40 QuakerState oil in, instead of the 10w30QS i'm running now. I don't know if my tune up will affect any of the other stuff, but it's all due anyway, so I'm grouping it together.
Am I just overreacting to how the car acts in hot (80-95deg) weather, or might I have an issue here?
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-17-2004, 03:56 PM
AFJuvat's Avatar
First off, what is "low"?
These cars at idle will drop to 1 - 2 bar of oil pressure - especially in hot weather.
When itis hot, switch to 20W50
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-17-2004, 09:08 PM
Send a message via Yahoo to bigyagi
your idle speed will also have a bearing on this reading. i believe that normal idle is 900, give or take. mine is set at 700, dont know why, but stinking hot, it was around 1.5-2 bar, with 5 at start up. if i held rpms at 1k, then oil p was 3.5 bar.
since changing the bearings, stinking hot, pressure is 3 bar at 700rpm, and at 900, its nearly 4.
as long as you still have normal readings at speed, i think you are ok. in the handbook, it says 4 bar at 5k. i'm willing to bet almost everyone here has that{4 bar} anywhere over 3k.
if you read posts on here all the time, you kinda develop an almost"sh$$t, somethings going wrong here" attitude!
bob.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 07-18-2004, 10:48 AM
AFJuvat
It does drop to 1 bar, but on its way it bounces to .5 and makes the light turn on for a second. Am I just paranoid?
bigyagi:
yeah, I think i probably need to stop reading everyone else's problems.
Old 07-18-2004, 11:31 AM
ok, no one should ever use 10w-40 oil of any kind. most respectable oil companies will not make the 10w-40 blend. i would suggest 15w-40 rotella shell. it comes highly recommended
screw the 20w50 and go straight 90. its an old engine.
Parting out an 83 with black interior and two red racing seats
Old 07-18-2004, 06:32 PM
