Thumbs up I finally found the leak...no I need opinions
After spending hours cleaning and laying under the car I found the pesky leak. Its leaking from the lower corner of the Filter housing assy right where it touchs the lower balance shaft housing. You can see the drip form then run down behind the part of the balance shaft housing that has the power steering mount.
Before I pull the filter housing, is there anyway that bad relief valve seals could cause a leak to seap here??
Here is a picture of an N/A housing ( I couldnt get a picture of mine) showing where the leak is.
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 07-17-2004, 04:25 PM
SoCal Driver's Avatar
It's the flat gasket that runs around the outside of the housing. You will have seal the entire assembly when you pull it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-17-2004, 06:43 PM
thanks, thats what I thought.
Sounds like a nice job for the next oil change
Old 07-17-2004, 07:39 PM
Requires an alignment tool for the oil pressure relief valve bore. Think with the 951 there are some exhaust plumbing issues to clear before you can get a good shot at the oil cooler.
Old 07-17-2004, 07:53 PM
