Eli K's Avatar
Question Low Pressure A/C fill valve???
Hi all..have a quick question. I am trying to refill my A/C and want to be sure I use the right valve...we've just moved so I can't find my Haynes manual and look it up.
There is a valve right next to the what looks like a reciver driver on the right side as I open the hood. I am guessing that's the high...having a hard time finding a low....any help would be great, as the car's just sitting there on the jacks with the hood open....
Old 07-18-2004, 11:11 AM
Eli K's Avatar
also just noticed that my ground wire on the steering column is dangling chopped off at some point, cant find where it comes out of the firewall to reconnect, any ideas?
Old 07-18-2004, 11:29 AM
Eli K's Avatar
another valve is on the compressor itself, and is a PITA to get to....hopefully that's not the low pressure one....
Old 07-18-2004, 11:31 AM
CT944's Avatar
Low side is on the compressor on the early models. Impossible to connect one of those filler cans to, unless you use an adapter.
2007 997 TT
1992 500e
Old 07-18-2004, 11:32 AM
Don 944 LA's Avatar
This question has been raised by many, including myself.
Napa has a 90 degree angle connector and there is a shorter AC belt that allows the compressor to be tensioned at at different angle.
I have yet to do mine, but I have the brass 90 degree connector, and I will be getting the belt soon.
do a search
hope that helps
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-18-2004, 11:59 AM
Eli K's Avatar
Thanks Don, I'm going to look into the connector (do you have the Napa part number by chance, also, where did you get the shorter belt?
Also, does anyone have any suggestions for the ground wire to the steering rack? mine is chopped off and just about 5 inches is hanging off the rack, I can't seem to find where it connects to or go to the firewall,etc. Pretty tough without my Haynes manual, if I don't find mine in the next couple of days I'll have to buy another one, again...
Old 07-18-2004, 05:55 PM
Just thinking out loud
mattdavis11's Avatar
Short belt:
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539275&prmenbr=5806
Original belt:
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15539279&prmenbr=5806
The wire just might be the horn ground that is supposed to be attached to the cross memeber.
91 FJ80
84 Ram Charger
Old 07-18-2004, 06:19 PM
Eli K's Avatar
Thanks...got that from one of the earlier posts...just looking for the 90 degree adapter now....,
Old 07-18-2004, 06:20 PM
Most auto parts stores will have the fitting. Imagine that!
91 FJ80
84 Ram Charger
Old 07-18-2004, 06:26 PM
Eli K's Avatar
Just got my R134 right angle valve fitting and the shorter belt from Napa..will attempt to do the conversion tonight.
Now if I could just find where that darn brown ground wire goes to I'd be in great shape....
Old 07-20-2004, 06:36 AM
It attaches onto the compressor and to the pressure switch, IIRC.
91 FJ80
84 Ram Charger
Old 07-20-2004, 06:49 AM
Eli K's Avatar
Are you sure we're talking about the same wire? The one I am refering to looks like a brown ground wire attached by a screw to the lower cross member. mine is severed about six inches from the cross member.
FRWilk mentioned in one of his posts that this is the ground for the horn.
Old 07-20-2004, 07:06 AM
well I replied to that one as well, yes that's the horn ground. There is also a brown wire that is for the compressor. I get mixed up now and then.
91 FJ80
84 Ram Charger
Old 07-20-2004, 09:10 AM
Eli K's Avatar
Thanks mattdavis. the problem is I can't see where the rest of the wire is comming from the firewall....6 inch severed wire hanging off the crossmember is all I see....
Old 07-20-2004, 11:37 AM
It comes straight off the rack. The bearings and bushings from the horn pad thru the column, fire wall all the way down to the rack won't allow it to ground. The only connecting (grounding) point is on top of the rack its self, with a similar screw that attaches to the cross memeber. The horn grounds out this way, but don't ask me why.
91 FJ80
84 Ram Charger
Old 07-20-2004, 12:09 PM
the connection on my manual rack is near the input shaft on the rack and a little to the right hand side of the car, I think. Give me a hour or so to confirm on the manual rack, yours may very. This wire isn't but maybe 6 inches long.
91 FJ80
84 Ram Charger
Old 07-20-2004, 12:19 PM
I always leave that tid bit out, damn. FR you are the master!
91 FJ80
84 Ram Charger
Old 07-20-2004, 12:26 PM
