AllPorsche944's Avatar
Porsche Crest Oil Pump & Cooler
Anyone ever attempt to replace the oil pump with the engine still in the car?
How difficult to replace the oil cooler as well?
_____________________________
88 944na Azure Blue
Boxster 5 Spokes w/Pirelli PZero Nero M+S
Zimmerman XDrilled all around
Nology Ignition System
Mass Flow Air (K&N + Ingen Technology)
BB Cat Back Exhaust
Old 07-19-2004, 10:15 AM
Stan944's Avatar
Replacing/servicing the oil pump and the oil cooler are two separate procedures. Resealing the oil cooler is not difficult, but a bit tedious, as you need to drain/refill both the oil and the coolant. I don't know about the oil pump, but I think you need to remove the oil pan to gain access (I might be wrong here), and this requires removing the crossmember,etc. - read many hours.
1983 red Porsche 944
Old 07-19-2004, 10:38 AM
