nephite1's Avatar
Car wont start (1984 944)
My 944 will turn over but will not start up.
THe car i think may not be getting spark, if so, what can i do to change that?
PLease help me.
Old 07-19-2004, 12:40 PM
Check the availability of a spark with starter fluid. If that fails (and I am going through the same thing with my '84) look at the suggestions under my post "Adios, perhaps". That is what I will be doing, eliminating the possibility of fuel pump failure, then the relay.
For ignition, there are suggestions on www.frwilk.com and www.clarks-gerege.com
Bob S. former owner of a 1984 silver 944
Old 07-19-2004, 12:47 PM
First you need to verify the "no Spark" condition. Make sure it's not a "No Fuel" or "no compression" problem.
A troubleshooting guide will help you a lot...even a general guide (although it would be preferred that it address this car specifily) So you don't miss anything. Have a repair manual for the car?
You'll need to start narrowing the problem down. Once you have an idea what system is not working, the people on this forum can really help you out.
Can start with some of these...
Check for loose ground wires.
Check plugs one at a time
check wires for resistance with Ohm meter
check dist cap / rotor
check compression
Check fuel pump relay switch too...
Old 07-19-2004, 12:54 PM
nephite1's Avatar
Thank you very muc hfor your advice. I have a new dist. cap and rotor. Bu ya, i think i should go buy a repair manuel. But how would you check for compression or the fuel pump relay switch not working?
Thank you
Old 07-19-2004, 01:30 PM
a.n.other's Avatar
Have a look at
http://www.clarks-garage.com/shop-manual/ts-01.htm
Clarks-garage.com is a brilliant place to start looking for all your broken 944 needs.
Andy
Lowered '84 944 no longer smokin!
Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!)
http://photos.yahoo.com/shineyblue944
Old 07-19-2004, 03:11 PM
nephite1's Avatar
thank you very much...any more advice is welcome
Old 07-19-2004, 03:32 PM
nephite1's Avatar
what is a timing light? i talkedto autozone and they have a spark tester for like 10.99...is it worth it or would i have something around the house that could test it?
Old 07-19-2004, 04:19 PM
