Poll: What be b0rked?
Poll Options
What be b0rked?
Burn the fire.
Brando's Avatar
Talking Guess what's broke this time!
Alrighty, i think i may know but i want to hear a few guesses from the pros (AFJuvat, SoCal, other mechanics).
Here's the symptoms:
- Excessive vibration in all RPM ranges.
- Engaging the clutch into first (to begin movement) results in horrible shudder in the front and rear end of the car.
- When pressing the clutch pedal in (disengaging the clutch) you can hear a high-pitched squeal/grinding noise from underneath the car and in the cab.
- Reverse gear will not engage/grinds whence attempting to shift to reverse.
- In neutral, allowing the car to coast going forwards or backwards, excess vibration and high-pitched squeal/grinding noises from under the car.
I wonder wonder wonder what's putting my car in the shop this time!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-20-2004, 09:38 AM
not sure what you doing to ur'e car but there should be a brando fund arranged here ..... sorry to hear
Flywheel Pilot bearing
Old 07-20-2004, 10:26 AM
Do you have a spring center clutch disk? Not being able to get into reverse suggests that the clutch is not disengaging.
My guess is that one or more springs have fallen out of the disk, unbalancing it (causing vibration) and getting caught in the pressure plate (making distressing noises) where they prevent full disengagement.
Jack up the back end. Put it in neutral. Turn one of the back wheels and see where the noise comes from.
'87 924S 5sp
Slowly recovering from a warped head
Old 07-20-2004, 11:33 AM
Burn the fire.
Brando's Avatar
Oh oh, you're all going to love this...
This is where i mention that i'm far from home, unable to use a shop or garage for another 2 weeks
Old 07-20-2004, 11:39 AM
Don 944 LA's Avatar
Where you at ????
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-20-2004, 11:47 AM
Burn the fire.
Brando's Avatar
House-Sitting in Rancho Cucamonga.
Old 07-20-2004, 11:48 AM
thamlin000's Avatar
While you're in the neighborhood, next Friday, tell Ice Cube I said "what up", aight?
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 07-20-2004, 01:06 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Sounds like something that happenede on one of my 924's.. Sheered off motor mount..JUst a guess
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 07-20-2004, 01:54 PM
AFJuvat's Avatar
Sounds like you ate a clutch.
They replaced your pilot bearing before and didn't replace your clutch??!!
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-20-2004, 03:00 PM
Just thinking out loud
mattdavis11's Avatar
clutch fork bent?
91 FJ80
84 Ram Charger
Old 07-20-2004, 03:09 PM
pokey's Avatar
Send a message via AIM to pokey
Sock elastic shot?
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 07-20-2004, 03:13 PM
pokey's Avatar
Seriously, I'd gues either a motor or tranny mount.
1956 Ford F250
1955 BMW R69
Old 07-20-2004, 03:14 PM
Burn the fire.
Brando's Avatar
Roger, they didnt ask me when it was apart if i wanted to replace it. I got the thing back and on the receipt it said in their inspection that it was "OKAY, DOESNT NEED REPLACEMENT". I dont think ill ever go back there, though. Unless it's to litigate.
AFJuvat
Old 07-20-2004, 03:29 PM
Burn the fire.
Brando's Avatar
Oh damn... i just saw the poll numbers.
I'm desperately hoping it's not an "all of the above" problem.
Old 07-20-2004, 03:31 PM
Don 944 LA's Avatar
At least the " X " is in the right place in your signature..
Sounds like we REALLY need a SoCal GTG / Wrenching session..
After I start workin again.. The front end is gettin done..
OH, also a certain piece will soon be coming from FR Wilk..
Let me know If I can Help dude
Old 07-20-2004, 05:10 PM
sounds like something (pressure plate / release bearing / clutch disk). Something is not allowing the clutch to disengage properly.
1987 944S
2000 passat 1.8T wagon
Old 07-20-2004, 05:22 PM
Burn the fire.
Brando's Avatar
*bump*
tach died today!
and... clutch is probably 95% wasted.
Old 07-21-2004, 05:24 PM
haha that's exactly what I was thinking.
Old 07-21-2004, 05:31 PM
Burn the fire.
Brando's Avatar
w00p! it's dead as of 5:50 pm.
Car stalled at a major intersection when trying to let the clutch. Then proceeded to instigate my wrath by not starting.
After a couple minutes it started up, i was able to limp the car, with much pushing, back to my friend's house in Rancho.
So, now im just hanging around, chillin wit dah 'Nilla Iyce. luckily i got a borrowed car until i can get the clutch fixed on mine.
I took a look under the hood... How much of a gap am i supposed to have between the flywheel and bellhousing??
Old 07-22-2004, 08:51 PM
Don 944 LA's Avatar
pretty soon your gonna get " The Talk "
Old 07-22-2004, 09:00 PM
