Freakin headlight motor
Headlights got stuck while trying to lower them a few months ago.
Bought a new headlight motor relay, worked fine for 3 months, then same problem.
SO..... I bought another motor relay, but it doesn't help this time. So is it the motor itself crapping out ($$$$), or the mechanical linkage between left and right side possibly binding? What the Hell? Last time when it got stuck it drained my battery and the headlight motor got real hot in the process. If I sound tired and drunk it's because I am. Thanks for any help.
Red 1967 Saab "96", needs help
Blue 2002 Pathfinder SE
1991 240SX-SE, auto, trans was shot - junked it
Old 07-20-2004, 10:29 PM
Send a message via Yahoo to bigyagi
ha ha, been there, got the t-shirt. its no fun driving along with your headlights going thru full rotation, AND NOT STOPPING! after a couple days, then they stuck in full up position. new relay, and headlight switch to follow. plus bucket of spare switch's/relays!
good luck with your repair.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 07-20-2004, 11:37 PM
Thanks. Where is the headlight switch, and how do I replace it? Are you talking about a switch inside/behind the headlight control knob on the dash?
Old 07-21-2004, 05:16 AM
Will the head lights go up, if you turn the motor knob a bit? If it is, you might have burned up the diodes in the motor when it over heated. That happened on my 924. Replaced motor all good now.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 07-21-2004, 08:42 AM
Send a message via AIM to 944imraan
The headlight motor fuse is a good one to know if you need to pull it quickly.
White 1985/1 944
--my first car
--limited slip differential
--cross drilled rotors
--omnimagnum high-energy ignition
--CB equipped
--laptop installed, seeking GPS chip
--keep the socks away from my car
Old 07-21-2004, 05:41 PM
Check the grounds first. Always. Mine were opening or closing partially. I simply unplugged the connection to the motor and plugged it back in. Problem solved.
Lots of grounds, lots of problems solved by cleaning them.
Good luck!
83 Silver 944/Auto/Cookie Cutters/No side strip moulding/Extra Saratoga top(w/no hardware though)
1980 Yamaha XS1100 Special My other project and daily driver
My kids say my hair matches the color of the car! Who's getting old?
Old 07-21-2004, 06:39 PM
