fast924S's Avatar
Send a message via AIM to fast924S
T-belt question
Im sure this is a stupid question but why is it so important to lock the fly wheel when doing the T-belt, I would think if you just line everything up and are carefull then you should be fine Right??? what am I missing here??
I do T-belts all day at a toyota dealer, interferience and non, 4cyl and 6cyl and we never lock the fly wheel on those.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-19-2004, 11:28 AM
In the case of the 944, it has a lot to do with the amount of torque needed to loosen (and tighten) the front crankshaft bolt. 210 Nm when installed, might be 250 Nm to loosen.
gb
Good luck, George Beuselinck
Old 07-19-2004, 11:43 AM
TCMdocs944's Avatar
Don't need to lock the flywheel for a simple belt job. As a matter of fact, it kinda hinders getting everything just right. Some folks just like the extra insurance.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-19-2004, 12:13 PM
Parrothead member
VINMAN's Avatar
Ive always done mine without locking the flywheel , never had a prob.
Vinny
Old 07-19-2004, 12:19 PM
jm951's Avatar
You only need to actually lock the flywheel when removing the crank nut. Otherwise, it helps to hold the crank at TDC while you're working on it.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 07-19-2004, 12:23 PM
unless you have the metal lower balance belt guard on your engine (which, i think was only on the S2's and 968's, but i'm not exactly sure which engines had it) you can change the belt without removing the crank nut (which means you don't need the lock). The belt will slip in around the plastic housing.
Mike
'92 968
'01 VW Jetta TDi
Old 07-20-2004, 06:47 AM
TCMdocs944's Avatar
Be patient when slipping the belt over the crank gears. It may not seem to fit at first but it will. Don't injure it in the process.
Old 07-20-2004, 08:20 AM
Eli K's Avatar
"Don't injure it in the process."
Or yourself for that matter. While doing the belts on my '87 the torque wrench slipped, while I was trying to tighten the crank bolt, and I ended up getting hit in the head, nearly passing out and blood gushing from the eyebrow for about 4 hours....
Old 07-20-2004, 08:36 AM
marko's Avatar
I'm doing the belts on my S2 now. I haven't seen this anywhere, but my S2 has an idle roller right on top of the crank sprocket that has to be removed to get the belt around the crank sprocket. The roller bolt is too close to the crank sprocket and slightly recessed so you can't get a regular wrench or socket on it. I had to go buy a 90 degree box wrench to get it off so that I wouldn't have to remove the crank sprocket.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 07-20-2004, 11:55 PM
Short socket worked for me. Just barely fit. I ended up cutting the rear cover under the crank pulley and now it slips right off so that I can change whatever I want without taking off the pulley. Water pump change tommorow.
1987 944S
2000 passat 1.8T wagon
Old 07-21-2004, 06:49 PM
