removal of power seat with no power?
i am trying to remove the power driver seat on a 88 944, but the wiring has been stripped from the car. I can't move the seat foreweard and backward because normally thats done electronically. I've done everything I can, and im close to just cutting out the floor pan cause its a parts car. Is there anyway to manually slide the seat foreweard and backward to get to the allen head bolts to remove it?
1979 Porsche 911sc - Supercharged and race ready 1982 Porsche 911sc - Project car |
Can you hook up a temp battery to it.. That may do it ??
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat |
there i only a battery pos-neg connections to the seat. as don noted just apply 12v at that point and move ot where you need to.
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
ive been looking for hours, I've found about 3 different connections and applied 12v to it, but that doesn't do anything
looking at my wiring digrham it shows the following pins for the seat junction block. should have 8 pins.
pin #2 on input is yellow/black 12v in pin #7 is ground, brown wire pin #8 red/black input 12v pins #1-3-5-7 on the seat look to be tied together as grounds pins #4-6-8 are tied together input. looks like pin #2 is specifiec to seat heater circut if equiped. so applying 12v to pin 4, 6, or 8 ( on seal block it is any of the 3 red wire terminals and the ground would be any of the terminals on the block that have brown wires. ..i hope this helps
Since when did the electrics in the seats move them fore and aft?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Driver
I have a black lever you pull on and push REALLY FRIGGIN HARD. WD-40 helps.
'87 944 |
When I first started cleaning up my car after it sat for a few years I actually had to prop a JACK between the back of the seat and the panel under the backseat to get the seat to even move...an inch. It took several applications of wd-40 and a ton of brute strength to get them. Took them out and oiled them and they work great now.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car 1987 944 -- soon to be 1987 944S2 |
