Custom User Title
Dave L's Avatar
passenger side window - no go
My passenger side window died on Sunday, nither the passenger side or the drivers side buttons would make it go up. I hoped (prayed) it was just a fuse and would check it when I got home. Later that day, it worked fine. Yesterday i took the car out, the window wouldnt go down, Picked up my wife, the window works fine.
Before, I tear into the door panel is there an obvious connector that may be loose? Has anyone had this problem before?
Old 07-22-2004, 08:36 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
You probably can just clean the switch/connectors.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-22-2004, 09:45 AM
entertaining the idea
UconnTim97's Avatar
I second the cleaning of the switches. I had a similar problem, and replaced the switches, and has worked fine ever since.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-22-2004, 01:54 PM
Custom User Title
Dave L's Avatar
That was my initial tought as well, BUT its happening with both switches.
Old 07-22-2004, 03:17 PM
UconnTim97's Avatar
I believe the passenger side switch works off of the one on the driver side. So if the driver side is bad, the one on the passenger side won't work either.
Old 07-22-2004, 07:27 PM
Eli K's Avatar
not true...my 84 passanger window won't work from the driver's side controls, but works fine through passanger, too many other problems to work on at the moment
Old 07-23-2004, 08:39 AM
adida(r 944)'s Avatar
mine works same as siberian's window switches. i clean the switch out once in awhile when i get tired of leaning over to use the passenger button, i think im on the need of a new switch.
85/1 944 project/restore/upgrade in process finnaly:
Bursch headers and cat delete pipe. fiberwerks front bumper and rear wing
cant spell forgive my "hukt on Fonix" it workt gud four mi
in the process of buying a car and a half garage with a detached house and fenced in yard
03 Eclipse GS
Old 07-23-2004, 09:32 PM
Send a message via AIM to 944imraan
I've seen this one before, and it turned out to be the switch.
White 1985/1 944
--my first car
--limited slip differential
--cross drilled rotors
--omnimagnum high-energy ignition
--CB equipped
--laptop installed, seeking GPS chip
--keep the socks away from my car
Old 07-25-2004, 03:59 PM
Send a message via Yahoo to bigyagi
only takes a minute or two, to take the switch out. usually, the contacts are all blackened, and there is not good electrical contact. you can scrape them clean, and they will work fine for a while, but this is only a temporary fix.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 07-25-2004, 07:36 PM
Custom User Title
Dave L's Avatar
I remember doing this on a somewhat weekly basis in an old BMW I had. Do I dare to see how much a new switch is.....
Old 07-26-2004, 05:23 AM
SoCal Driver's Avatar
If the passenber window will work one way and not the other it's the switches. Sounds like you might need new ones. They do wear out.
You could try cleaning them. The later smaller window switches are much easier to clean as they do not have the bent ends on the contacts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-26-2004, 08:25 AM
Parrothead member
VINMAN's Avatar
I had the same problem with mine the passenger side or the drivers side, neither one would open the passenger window.
turned out to be a loose conection on the driver side switch.
Vinny
Old 07-26-2004, 08:30 AM
Bay Area Patriot
TheStig's Avatar
wow my old car did this! I replaced both switches to be sure that both sides would lower the window and I never had a problem after that. Also check the connections. Good Luck
Andy
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 07-26-2004, 09:04 AM
I think the single switch is about $30, don't know about the double.
White 1985/1 944
--my first car
--CB equipped
Old 07-26-2004, 02:14 PM
They are the same switch.
Old 07-26-2004, 04:54 PM
SoCal is right, excuse me.
White 1985/1 944
--my first car
--CB equipped
Old 07-26-2004, 05:04 PM
One of the few consitancies.
Old 07-26-2004, 05:37 PM
