Inside air adjustment - heat/air cond.
I don't have a book, so can someone tell me what the slide bars for heat and air do. The top one does what? The bottom one does what? What does it take to turn on the A/C. Thanks to All.
Old 07-22-2004, 09:32 AM
Don 944 LA's Avatar
I've been wonderin that myself. I sort of have it figured out.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 07-22-2004, 10:40 AM
s928s's Avatar
I believe the upper varries the flow fror the upper dash registers (Face), the lower varies the air flow from the lower dash vents ( foot ) . sliding to the left is less air flow, to the right is more. Of coarse the center vent slider controls the defront and center vent flow. the "*" is to turn on the compressor and the temp should be set to the desired low temp.
the recirc button( 3 circular arrows) has an odd note in the manual, states that is is used for cutting off fumes from veh. ahead of you and should not be left in that position becaust the windows may fog !!! nothing about it helping to recirc the cabin air to lower the temp faster !!
the manual also notes the "a/c" vent in the glovebox and to lower the windows when first using the a/c when the car sat in the sun all day .
..there is not alot of info there !!
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 07-22-2004, 04:40 PM
