Porsche Crest 944 Plug Install
Ok I bought the Bosch Super Plugs for the 944. I will be installing tommrow afternoon. I have NEVER installed a spark plug in a 944 or any car to be exact. Can you experts please walk me through exactly what I have to do.
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 07-22-2004, 06:25 PM
Driver
If you are just doing the plugs it is very easy. Get a torque wrench so that you tighten everything correctly.
Pop the ignition wires off of the top of the plug (grip from the boot, not the wire) and twist gently. Unscrew the old plug and screw the new one in.
Make sure you blow any dirt or dust away from the plug holes before AND after you take the ignition wires off. Also put some of the thread compond specifically for sparkplugs (it escapes me what it is called, but the guy at the parts store will know) on the threads.
Also I always start at the back & work my way forward so the job gets easier as you go.
Enjoy,
GHEN
'87 944
Old 07-22-2004, 06:34 PM
Eli K's Avatar
apply anti-seize compund to the threads...any parts store should have it
Old 07-22-2004, 06:48 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Di-electric grease for all connectors. Makes it easy to get apart and keeps the water out.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 07-22-2004, 08:47 PM
Anti-Seize onto the threads right? How about the D-Elect. grease where should this go, im thinking onto the top of the plug??? I dont have a torque wrench either.
72 914 Sold
84 944 Sold
85.5 944 Sold
Old 07-23-2004, 08:58 AM
Eli K's Avatar
put it a little bit of grease on top of the plugs... since you don't have a torgue wrench, screw in the plugs hand tight and then add about 1/8 of a turn....no more...
Old 07-23-2004, 09:00 AM
Bosch plugs already have thread lubricant on them. There is no need, and Porsche does not recommend, any anti-sieze grease to be used.
O2 sensors don't like anti-seize.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-23-2004, 09:03 AM
Driver
Auto-Zone has a tool lending program if there is one near you. You can do it by hand but why not be 100% sure; especially since this is your 1st time?
GHEN
'87 944
Old 07-23-2004, 10:39 AM
winter-hater club member
nynor's Avatar
i just changed my plugs. i forgot to lube the boots with dielectric grease last time. i didn't think i'd be getting them out. it took just about all my strength to get them off.
i remembered this time.
"COOL PRIUS!" - Nobody Ever
Old 07-23-2004, 12:28 PM
Britwrench, Porsche doesn't reccomend di-electric grease either (tends to attract and hold dirt). Do you use or reccomend either? I know I would trust you and several others on this board rather than some corporate statement that may or may not be motivated by profit or legal concerns rather than what is best for maintenance. By the way, I use both di-electric grease and anti-seize (hadn't heard about O2 sensor sensitivity, and will be more careful in the future, thanks).
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 07-23-2004, 01:06 PM
I'm in two minds on the die-electric grease. I don't think it hurts, but too much certainly does, especially on 944/928 engines. The grease forms an air tight seal so when the plug cap is pushed on, the air is trapped. As the engine is warmed the trapped air might push the cap loose. Anyway if you do use it, only a little is required.
Old 07-23-2004, 01:16 PM
Driver
Man this is a lot of discussion to change 4 plugs
GHEN
'87 944
Old 07-23-2004, 02:04 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
heh, how many 944 owners does it take to change a lightbulb?
answer: holdon, lemme check Haynes
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-23-2004, 02:40 PM
Send a message via AIM to 944imraan
It's because the lightbulb is behind another part and may only be reached from below with the ring finger on your left hand, and may only be seen from above.
White 1985/1 944
--my first car
--limited slip differential
--cross drilled rotors
--omnimagnum high-energy ignition
--CB equipped
--laptop installed, seeking GPS chip
--keep the socks away from my car
Old 07-25-2004, 04:03 PM
Mytoy944's Avatar
As a part time Zoner (thats what they call us AUTOZONE employees!) I can confirm that we will be more then happy to "loan" you the torque wrench you require (pay for it when you take it, and get a full refund when you return it) Also, on the antiseize, dielectric grease issue, AUTOZONE calls it WITTDJR (what it takes to do the job right) I call it Get a couple of extra bucks from the cusatomer!
98 boxster
86 944 n/a by choice still for sale!!!!!!
90 legacy wagon by neccessity ( now dead! thanks Alex!)
02 hyundai by mistake
02 WRX (damn this thins fast!!!) Now it's gone!
2000 Subaru Legacy. (damn this thinns slow!)
92 Corolla (that'll teach ya to total my subaru Alex!) Now dead! (hey kid! ever hear of oil?)
Old 07-25-2004, 05:15 PM
Driver
To clarify, the tools you get are part of the loaner program. They charge your card as a deposit.
GHEN
'87 944
Old 07-25-2004, 07:08 PM
Eli K's Avatar
I'd love to see this post go past two pages.....
Old 07-25-2004, 07:10 PM
speaking of tool-lending... Is there anyone here who rents out a tensioner?
Old 07-25-2004, 08:37 PM
We rent out the tensioner... call me for details.
gb
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 07-26-2004, 03:59 AM
Driver
The socket slipped over the plug end, coming together as easily as two lovers after a long seperation. It was as if they were made for one another; and in fact they were. Randolph's sinewy muscles sprang to life as he grunted with the effort required to free the recalcitrant plug from its shadowy den. He allowed his mind to wander forward to when he could again drive his beloved Porsche, to see the exhaust billow forth as if from a dragon's snout, and hear the roar of the engine.
There, I've done my part.
GHEN
'87 944
Old 07-26-2004, 05:33 AM
