bryanthompson's Avatar
Send a message via ICQ to bryanthompson Send a message via AIM to bryanthompson Send a message via Yahoo to bryanthompson
fan hitting lower radiator hose
I got my cooling system flushed the other day. They found that my headlight assembly was hitting an upper radiator hose and was starting to wear a hole. Anyway, they put a new hose on and finished the job.
This afternoon I got done changing my spark plugs and noticed that my right (passenger side) fan lightly hits my lower radiator hose. Is there a bracket or some kind of shield I can get that will keep the hose further away? There's no room to just push the hose aside, maybe I can move the fans over a little bit?
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-23-2004, 01:42 PM
entertaining the idea
UconnTim97's Avatar
I had this same problem when I upgraded to 6 blade fans. You can cut a small amount off the top end of the lower radiator hose and reinstall it. This will keep it far enough away from the fan.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 07-23-2004, 02:00 PM
CT944's Avatar
I had the problem as well. Just loosen the lower radiator hose and pull it out a little, then re-tighten. It should be about 1/4 inch away from the fan.
2007 997 TT
1992 500e
Old 07-23-2004, 02:49 PM
SoCal Driver's Avatar
Bet your engine mounts are shot.
Giving the hose a twist at the water pump may help.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-23-2004, 04:38 PM
Used & Abused
Does your radiator move around at all? Your radiator might have "fallen out" of it's mounts.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 07-24-2004, 02:43 AM
Well, i'm pretty sure Hugh is right again. I did the engine mount test, and they're pretty much nonexistant. Once I get my ramp-lift built, that'll be the first thing I do.
Old 07-24-2004, 07:13 AM
I didn't mean to sound so disappointed about Hugh being right. it's just that every time he is, it costs me money I truly appreciate the help though
Old 07-24-2004, 07:14 AM
bearone2's Avatar
socal is just plain wonderful.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 07-24-2004, 03:59 PM
OK Ken, your $10 is in the mail.
I found out a few years ago that the fan hitting the hose was because my engine mounts were bad.
Old 07-24-2004, 08:30 PM
bearone2's Avatar
Cool
thank you, thank you very much.
you could probably forget more than most of us will ever know.
Old 07-24-2004, 08:56 PM
I used to know more but I've forgot what it was.
Old 07-25-2004, 03:01 PM
