Col Col is offline
Rough idle when cold
Hi
I have a 1984 N/A 944.
Lately when cold the car starts fine but idles roughly and I need to keep my foot on the accelerator to keep it running smoothly.
The idle speed is about 6,000 rpm at this stage.
When warm it idles fine at about 8,000 rpm.
Any advice on the possible problem.
Cheers
Col
Old 07-25-2004, 06:50 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
This is joke right?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 07-25-2004, 07:11 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
I believe he's adding one too many "0" to his idle numbers...a little common sense could tell you that...but a smart-ass un-helpful post was far more apropriate, I'm sure.
General tune-up. Check your plugs and wires. Then check your filters. If none of those help the situation start searching for a vacuum leak.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 07-25-2004, 07:24 PM
will944's Avatar
Send a message via AIM to will944
Yeah....I would definitely check your vacuum lines....typically break around the Idle Stabilizer under the Intake.
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 07-25-2004, 08:03 PM
Col Col is offline
Sorry. I did put an extra "0" in the idle speed.
Thanks for the responses I will check plugs ,wires, filter and vacum as you all suggest.
Cheers
Col
Col
1984 n/a 944 RHDrive Guards Red
Air/Con 130,000 km
Old 07-25-2004, 08:17 PM
^I have to look into that myself....
Old 07-25-2004, 10:03 PM
krahm's Avatar
All good suggestions. It could also be a combination of problems, though, so if you do all the above-mentioned things and you still haven't got it running quite right, think about pulling the injectors and having them cleaned and tested. Also, check to make sure the 02 sensor is working properly.
'87 944S
'73 MGB (in progress)
Old 07-26-2004, 12:07 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
my idle would sometimes be a little rough. i readjusted the idle to sit between 900 and 1000, knowing damn well that i need new plug wires. It helped a lot, and the new wires are on their way.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-26-2004, 07:58 AM
Bay Area Patriot
TheStig's Avatar
usually a really bad idle like that can also contribute to a ripped intake boot. Check that area. If not check the vacuum lines under the throttlebody and boot and to the auxiliary air regulator. I had a loose one on this newer car and I had the worst idle.
Andy
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 07-26-2004, 09:16 AM
"usually a really bad idle like that can also contribute to a ripped intake boot."
How does a bad idle rip the boot?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-26-2004, 11:23 AM
Send a message via Yahoo to Cebu
I agree withe the assesment of tears/cracks in the intake boot..my personal experience.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 07-26-2004, 11:55 AM
Col Col is offline
Thanks all for your advice. I will give all the items mentioned a good check on the weekend and replace as necessary. Will also adjust the idle speed and if no improvement replace the aux air valve.
Cheers
Col
Col
Air/Con 130,000 km
Old 07-26-2004, 05:21 PM
