Turbo oil feed question
I'm assuming that the 944 and 951 have the same block, just different internals. If so, where's the oil feed for the turbo?
http://forums.pelicanparts.com/uploa...1093905626.jpg the "baby" that comes first... |
The balance shaft housing on the drivers side....... and returns through a passage in the motormount (turbo sits on mount) down to the bottom of the pan.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
sweet. Thanks man!
ok...can't quite locate it. Would anyone be so kind as to snap a pic of their turbo engine bay showing where the oil feed is on the block?
It's the braided line that goes behind bolt.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
Lawrence, is there any way oyu could pan out on that pic some?
Panned
