Is a 944 supposed to idle rough ???
I know my 924 idles rough but is my 944 supposed to ??? Its really rough, Im hoping a simple tune-up will fix the problem. Any thoughts or suggestions ?
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 07-29-2004, 07:15 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
You know....I was gonna ask this same thing. Mine is quite rough down low, especially when cold. I have the idle set at 950/1050 (load) to even her out.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 07-29-2004, 07:33 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
mine idles rough at first, and then smooths out after about 2 mins, or just a couple seconds of driving. It hasn't always been like that, so i figure it has something to do with my crappy plug wires?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-29-2004, 07:39 PM
That's what I'm leaning on....bad wires. I think I'm gonna order up some 8.5mm wire and boots and put together my own wires. $150 for quality wires is BS.
Old 07-29-2004, 07:43 PM
Stan944's Avatar
A vacuum leak is likely to make it idle rough.
1983 red Porsche 944
Old 07-30-2004, 07:16 AM
I've got Magnecor wires on mine. I think they were $89 or something like that. The're non-resistor supression wires. I don't know if i got any HP out of them, but it runs better after i installed them
Mike
'92 968
'01 VW Jetta TDi
Old 07-30-2004, 08:42 AM
Chris_924s's Avatar
Motor mounts will contribute to rough idle feel as well.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 07-30-2004, 08:55 AM
Stan944's Avatar
hey Chris,
Like you said, I also noticed a substantial improvement of the idling (less rough) after installing new motor mounts. I don't fully understand, but think that it's related to vacuum: a stressed (because the motor is lowered with a collapsed mount) vacuum hose (e.g. the J-boot) would not properly seal to its connections. What do you think?
Stan
Old 07-30-2004, 10:36 AM
Writer/Teacher
CJFusco's Avatar
would a vaccuum leak have a rough idle that smooths out after only a few minutes?
Old 07-30-2004, 01:30 PM
nige944's Avatar
Define rough idle....
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 07-31-2004, 03:28 PM
Writer/Teacher
CJFusco's Avatar
engine sounds "rougher" and steering wheel vibrates more than when the car is warm
Old 07-31-2004, 07:50 PM
Every 944(Every porsche for that matter) has been like this.. it feels like more of a rumble to me. A nice rumble, though....
Old 08-01-2004, 02:51 AM
Chris_924s's Avatar
Check the vacuum line attached to the brake booster... as well as the ancillary vacuum lines connected to it.
That's been known to produce these conditions as well.
TENSION YOUR SOCKS!
Old 08-01-2004, 05:52 AM
