Oil Pan Gasket change?
To change the oil pan gasket, can I drop it down a few inches without taking off the cross member, and install another gasket? Has anyone tried ? Thanks, 1986 na
Old 07-30-2004, 09:44 AM
Chris_924s's Avatar
Yep. done it. It takes forever and you'll be struggling with torquing the bolts directly above the crossmember as the torque wrench wont fit.
Can it be done? yes. It will take substantially longer.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 07-30-2004, 09:47 AM
Thanks for the info.
Old 07-30-2004, 09:49 AM
rudidelange's Avatar
I replaced the Gasket by removing the cross member bar at the bottom. Its leaking again, so in my next vacation I will have to it over agian. The factory manual stated that a sealant (silastic RTV?? as far as I can remember) must be placed on the inside and outside at the corners of the gasket - so I placed an alternative sealant at the bottom of the gasket - not on the top - guess what - it leaks at the top. I also stripped one bolt hole in the block- DONT OVERTIGHTEN!!!
Enjoy the work and put sealant at the cormers, TOP and BOTTOM.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 08-02-2004, 03:01 AM
Chris_924s's Avatar
The torque sequence on the Oil pan is very specific.. it wa a center out cross pattern with 3 sessions of succesive torquing. Make sure to follow the book on this.
TENSION YOUR SOCKS!
Old 08-02-2004, 03:44 AM
