Front end alignment?
What are the factory specs for the front end alignment, and does anyone know what the proper camber of the front wheels should be while the car is on jack stands or when the car is siting?
I can get the proper specs at work I think? I will check the aligment machine if it has the data. What year and model, 84 944??
My car kept pulling to the right, untill i check the tire presure today, and realized that I was running 10 psi on the right front tire. After I inflated it to 29psi, it ran as straight as an arrow...
I put in a new strut assembly so air pressure is not an issue and fast924S it is a 84 944 thanks for looking for me
| All times are GMT -8. The time now is 04:37 PM. |
