Centerforce clutch
I bought a duel friction Centerforce clutch for my 1983 944. When I installed it I found it had a grinding when I engaged the clutch. After taking it all back apart again I found that the added weights that are on the pressure plate were rubbing and grinding against my clutch fork. When I looked on Centerforces website I believe it said that the added weights were not put on my model of car because of clearance issues.
Has anyone ever had this problem? Should I just remove the weights? Any help would be very much appreciated (taking the clutch out of this vehicle is not an easy job).
04 infiniti G35
Old 08-01-2004, 02:55 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Contact the manufacturer...not the manufacturer's clients.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-01-2004, 03:22 PM
fast924S's Avatar
Send a message via AIM to fast924S
I would check with the manufaturer before doing anything. Maybe the packaged the clutch wrong or something. I would NOT remove the weights from the clutch since it may be designed to use them and could blow apart with out the weights.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-01-2004, 07:38 PM
