engine going back in. 2 questions
1st, should there be any resistance when I push the pivot fork in where the slave cylinder hooks up? I can push it all the way back with no effort and it only seems to move the bearing a litle bit.
Also, how long are the bolts that hook the torque tube to the bellhousing? Thanks in advance for any and all help. |
There should be some resistance once the pivot shaft is in place.
About 2 - 3 inches, 17mm head AFJuvat |
| All times are GMT -8. The time now is 01:54 AM. |
