AllPorsche944's Avatar
Porsche Crest MO30 Sways Question????
Anyone take a 944na and upgrade with front and rear MO30 sway bars? What did you think?
88 944na = Azure Blue
New Rebuilt Race Engine (@190 HP)
Lindsey Racing Fuel System
MSD Ingnition System
Zimmerman XDrilled Frt/Rear
BB Headers & Cat Back Exhaust
Mass Flow Air w/ Ingen Technology
Nology Pro Fire Wires & Coil
Millie Cup Wheels and Kuma's
Old 07-30-2004, 09:22 PM
Its been done...does wonders.
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 07-30-2004, 10:21 PM
Send a message via AIM to shocker1322
I put MO30 sway bars on my 924S. The worst part was fabricating the pieces to make the front work. The rear bolted up with no problem. I am not sure if the front will just bolt onto a stock 944, the hangers that are used are from a turbo and 968. If your current sway bar is held on by a U shaped clamp, you will need to get a different hanger.
As far performance, they definitely help. The rear is not as aggressive as I would have liked it to be. Right now I have my rear set to maximum stiffness, using both the bolt holes and droplinks. There is not a hint of oversteer, which to me says that they should be stiffer. Adjustments should make the car go from an understeer to an oversteer. Yet it seems like it just goes from a understeer to neutral. Of course there is a 30 mm front bar it has to overcome first. Overall they are a definite plus.
'87 924S, Hawk HP Plus Pads
Centerforce clutch and pressure plate
968 M030 Front and Rear anti-sway bars
28mm Sway-Away Torsion Bars
275 lb/in hypercoils, adjustable Koni's
Old 07-31-2004, 04:34 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
shocker-put the factory front sway bar on and leave the M030 rear, I think you'll find the lost oversteer.
allporsche-search, this has been discussed
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 07-31-2004, 09:48 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
my 924S came with MO30 and i like it.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 08-01-2004, 07:20 AM
bump
Old 08-02-2004, 05:27 PM
Why did you bump this? It was answered
Old 08-03-2004, 07:31 PM
