pressure plate bolts
I am doing a cluch job, with engine out.
I am re-assembling. When I install the pressure plate, the bolts don't tighten down completely flush. I assume they need to be torqued down flush, otherwise I'd think it will wobble or work loose. Am I correct?
Would it be ok to put washers on the bolts so they can be tightened flush?
Old 08-01-2004, 07:43 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
Re: pressure plate bolts
Did the bolts come with the clutch kit? Are they the stock bolts? Where did you get them? If they came out of the stock clutch and were flush there then you shouldn't have problems now. If they are the stock bolts I would suggest getting slightly short bolts or adding lock washers.
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-01-2004, 07:58 PM
I am using botls left over from CV axle job. They are slightly shorter and have a little less thread on them. Being shorter, I'm surprised they won't tighten flush.
I think I may just go buy new bolts tomorrow.
07 Yukon Denali Blue Green Metallic, rolling on 22's
05 Jeep Laredo careened around town by child #1
06 Mustang rolling around town by child #2, in all it's bass thumping glory
88 928 S4 Black 90 928 S4 Linen Grey Metallic Sold
88 924s Black Sold 85.5 944 NA Grey Sold
Old 08-01-2004, 08:00 PM
fast924S's Avatar
Send a message via AIM to fast924S
WOW DONT! use any ordanary bolts on the flywheel!!!! The flywheel usually uses special bolts, I think they are like grade 12. I would make sure you get the correct lenght and strenght bolts before you do this, There is alot of rotating mass at the fly wheel, The last thing you want is it to come apart and blow a hole in the bellhousing.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-01-2004, 08:44 PM
Used & Abused
Hey, at least it'd be easier to do the next clutch change!
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 08-04-2004, 09:39 AM
